Case statements :(
jacqueskleynhans
Case statements :(
PostPosted: Fri Aug 22, 2008 5:28 pm     Reply with quote
How does a case statement work i have looked in the ccs manual but still a bit confused Confused . I need to ask the user to perform an action with printf then press any key to continue. Perform an ADC then continue on to the next state ment.
*is this right*
for (ctr=0;ctr<9;ctr++) {
      switch (ctr) {
      case 0:
         printf("Move up and press any key\n\r");
    getc();
            *perform action* and go to next case
      case 1:
         printf("Move Down and press any key\n\r");
         getc;
"THE ONLY EASY DAY WAS YESTERDAY"
PostPosted: Fri Aug 22, 2008 6:13 pm     Reply with quote
The case statement is a basic C language construct. If you want to learn on how to use it I suggest you buy a good book on the C language. These books are much better in explaining the language than the CCS compiler manual and you will use them a lot. Much better and quicker than asking basic questions here in the forum.
What you want to do in your program is a technique called 'state machine'. A good explanation of this technique can be found at http://www.aqdi.com/state.htm
jacqueskleynhans
PostPosted: Fri Aug 22, 2008 6:51 pm     Reply with quote
I solved it. But I'm getting an error:
The state machine is to calibrate an accelerometer.
Executing: "C:\Program files\Picc\CCSC.exe" +FM "main.C" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 15(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 28(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 42(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 52(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 64(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 76(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 87(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 99(20,29): Expecting function name
*** Error 53 "C:\Users\BETTIE\Documents\Work\ADC_CAL.C" Line 110(20,29): Expecting function name
9 Errors, 0 Warnings.
My code :
void calibrate(void) {
   for (cnt1=0;cnt1<9;cnt1++) {
      switch (cnt1) {
      case 0:
         printf("Orientate Xaxis UP and press any key to continue.\n\r");
             getc();
     X1 = Y1 = Z1 =X2 = Y2 = Z2 = X3 = Y3 = Z3 = 0;
    for(cnt2 = 0; cnt2 < 8; cnt2++)
             set_adc_channel(1);       // Select the A/D channel
             delay_us(20);             // Aquisition time
             X1 += adc_value();        // read the raw adc value
             X1 /= 8;
      case 1:
         printf("Orientate Xaxis Down and press any key to continue.\n\r");
         getc();
             X2 += adc_value();        // read the raw adc value
             X2 /= 8;
      case 2:
         printf("Orientate Xaxis Horizontal and press any key to continue.\n\r");
         getc();
             X3 += adc_value();        // read the raw adc value
             X3 /= 8;
        case 3:
           printf("Orientate Yaxis UP and press any key to continue.\n\r");
           getc();
             set_adc_channel(2);       // Select the A/D channel
             Y1 += adc_value();        // read the raw adc value
             Y1 /= 8;
      case 4:
         printf("Orientate Yaxis Down and press any key to continue.\n\r");
         getc();
             Y2 += adc_value();        // read the raw adc value
             Y2 /= 8;
      case 5:
           printf("Orientate Yaxis Horizontal and press any key to continue.\n\r");
           getc();
             Y3 += adc_value();        // read the raw adc value
             Y3 /= 8;
      case 6:
         printf("Orientate Zaxis UP and press any key to continue.\n\r");
         getc();
             set_adc_channel(4);       // Select the A/D channel
             Z1 += adc_value();        // read the raw adc value
             Z1 /= 8;
      case 7:
         printf("Orientate Zaxis Down and press any key to continue.\n\r");
         getc();
             Z2 += adc_value();        // read the raw adc value
             Z2 /= 8;
      case 8:
         printf("Orientate Zaxis Horizontal and press any key to continue.\n\r");
         getc();
             Z3 += adc_value();        // read the raw adc value
             Z3 /= 8;
RayJones
PostPosted: Fri Aug 22, 2008 11:43 pm     Reply with quote
Should be read_adc() instead of adc_value() perhaps?
jacqueskleynhans
PostPosted: Sat Aug 23, 2008 2:46 am     Reply with quote
Thanks that makes total sense wrote this code at 3 this morning.
Kind Regards
jacqueskleynhans
PostPosted: Sat Aug 23, 2008 3:13 am     Reply with quote
Thw victory was short lived
Getting same error
void calibrate() {
      switch (cnt1) {
      case 0:
             getc();
             adc_value  = read_adc();  // Read from specified channel
             X1 /= 8;
RayJones
PostPosted: Sat Aug 23, 2008 3:37 am     Reply with quote
you still have brackets after adc_value !
jacqueskleynhans
PostPosted: Sat Aug 23, 2008 3:43 am     Reply with quote
Yea i noticed its working now Thanks
