rotate bits.... easy for the pro's
dave200
PostPosted: Tue Aug 19, 2008 3:48 am     Reply with quote
Guys,
I have the value 0x94 (10010100) but want to shift the bits to make 0x29 (00101001)
would the statement below be correct?
If not how would i go about doing so?
value = (0x94 >>= 7);
Smile
PostPosted: Tue Aug 19, 2008 4:14 am     Reply with quote
First key thing, is that you need a rotation, not a shift. The 'C' >> operator, is a shift. With a shift, when bits get to the 'end' of the byte/word, they are lost off the end.
CCS, has a 'shift_right', and 'shift_left' instruction.
Second thing is though, that if you are dealing with a single byte, if the shift/rotation goes for more than four bits, it is quicker to go the other way round. So in your case, shift left by one, rather than right by seven.
Third thing though, is I presume the value is in a variable, not a constant as you show. Otherwise much quicker for everyone just to just do the shift yourself...
So (for instance):
int8 value;
value = 0x94; //Starting point
shift_left(&value,1,1);
//Now value will be your required answer
dave200
PostPosted: Tue Aug 19, 2008 4:23 am     Reply with quote
Thanks Ttelmah!
One thing i did notice in your reply is that you state i require a rotate not shift, but your example shows "shift_left".
Is that correct or do i want the rotate_left?
Thanks and regards
Very Happy
Wayne_
PostPosted: Tue Aug 19, 2008 5:53 am     Reply with quote
Ttelmah is assuming that the MSb of value will always be 1.
To rotate 1 bit to the left
int carry;
int value;
value = 0x94;
carry = (value >> 7);
value = (value << 1) + carry;
OR
rotate_left(&value, 1);
PostPosted: Tue Aug 19, 2008 7:08 am     Reply with quote
Yes, I meant to use 'rotate'. Shows how easy it is to make mistakes.... Smile
Humberto
PostPosted: Tue Aug 19, 2008 1:15 pm     Reply with quote
dave200 wrote:
I understand that what you want is to reverse the order of the bits, not to rotate nor shift them. If this is what you want, in the following thread you will find an interesting discussion regarding how to.
http://www.ccsinfo.com/forum/viewtopic.php?t=23364
regards,
Humberto
