suggest a PIC development board with the following features:
jds-pic
PostPosted: Wed Aug 13, 2008 2:13 pm     Reply with quote
please suggest a PIC development board with (or approximately with) the following features:
- PIC with native USB, e.g. PIC 18F4550, @20MHz.
- USB port powered/DC power optional/selectable.
- 9Vdc -> 12Vdc power input.
- RS232 port.
- LEDs, 3 or 4 would be good.
- LCD, 2 x 16 or so. backlight nice, not req'd.
- pushbutton switches.
- small breakout area or expansion connector -- some way to use the board for bigger things; e.g. for adding memory (SEEPROM), or for attaching the board to sharks with lasers on their heads.
- cost < US$100, prefer < US$75
- commonly available from a vendor that will be around for some time, e.g. if i buy 10 units now, i can buy 6 more units in 6 months.
CCS, sparkfun, etc don't seem to have anything that meets most of these. btw, a modular approach is ok; e.g. an LCD that sits on an expansion header.
suggestions welcomed.
thanks much,
jim / jds-pic
newguy
PostPosted: Wed Aug 13, 2008 2:31 pm     Reply with quote
Have a look at Mikroelectronika. http://www.mikroe.com/en/tools/ After a quick look it seems as though they may have several boards with the features you want, but not at the price you want. I've never purchased products from them, but I did have a few former students who did. They were happy with the development boards they purchased.
drh
PostPosted: Wed Aug 13, 2008 2:50 pm     Reply with quote
Another site to check
www.olimex.com
David
PostPosted: Wed Aug 13, 2008 4:55 pm     Reply with quote
Yes, Olimex was the company I was thinking of too.
This board for EUR24,95 seems to meet the specifications, except you have to add your own LCD.
A separate LCD has the advantage that it's easier to mount in a housing and you can choose the LCD to fit your application's requirements.
Also promising: http://www.olimex.com/dev/pic-lcd3310.html.
For EUR49,95 you get: 48x48 pixel display, USB, joystick, SD/MMC connector AND a 3-axis accelerometer! A perfect fit for your shark/laser project. :-)
Note: the prices are excluding VAT. EU-members will be charged an extra 20% VAT.
jds-pic
PostPosted: Wed Aug 13, 2008 10:12 pm     Reply with quote
For EUR49,95 you get: 48x48 pixel display, USB, joystick, SD/MMC connector AND a 3-axis accelerometer! A perfect fit for your shark/laser project. :-).
i had looked at the Olimex boards prior, but there would be a lot of foundation work for the students to do -- namely, wire up the LCD and the RS232 level converter before any actual SW experimentation could start. i don't think my "requirements" are that esoteric yet i can't find an LCD-equipped dev board which has native USB and a serial port.
thanks for the leads.
jim / jds-pic
newguy
PostPosted: Wed Aug 13, 2008 10:25 pm     Reply with quote
http://melabs.com/ ME Labs have a USB development board, but it's $180.
Since this is for students, is there any chance you can lay out a board yourself and distribute the thing as a kit? It would be quite inexpensive, particularly if you order 100 boards at a time. The same goes for 100 of each part for the kit.
ME Labs actually posts the schematic for each of their boards, ie here for their USB board: http://melabs.com/downloads/LABXUSCH_06.PDF. It wouldn't be hard to quickly bang up your own solution. If it was a kit the students could add to it as they saw fit as well, for instance opting for a backlit LCD instead of the non-backlit "base" model.
jds-pic
PostPosted: Thu Aug 14, 2008 7:35 am     Reply with quote
it's an "introduction to programming the PIC" type course, not an "introduction to hand placement of SMT parts" type course... Wink
nevertheless it is an option we are considering for the long term.
jim / jds-pic
mmprestine
PostPosted: Thu Aug 14, 2008 7:52 am     Reply with quote
This might fit the bill.
Matt Very Happy
Board
http://www.futurlec.com/PIC18F4550_Board.shtml
RS232 cable and LCD with cable
http://www.futurlec.com/DevBoardAccessories.shtml
total: $61.30
jds-pic
PostPosted: Thu Aug 14, 2008 8:04 am     Reply with quote
total: $61.30
matt,
nice find -- that is the exact setup i am currently looking at.
jim / jds-pic
