Trying to capture data from another device
PostPosted: Sat Aug 09, 2008 1:44 pm     Reply with quote
Im trying to capture the data from a handheld laser range finder. Specifically, I'm reading the three logic signals going to the lcd. There is a data signal, a clock signal, and an enable signal. I'm guessing that this is an i2c bus, but I'm not sure.
#int_ext
void ext_isr() //enable
  if(int_edge_flag == 1)  // edge = H_TO_L, data is coming
    ext_int_edge(0, L_TO_H);  //toggle edge for next isr iteration
    int_edge_flag = 0;      //flag to denote trigger edge
    enable_interrupts(INT_EXT1);
  else  //edge = L_TO_H, time to print packet
    ext_int_edge(0, H_TO_L);
    int_edge_flag = 1;
    disable_interrupts(INT_EXT1);
    disable_interrupts(INT_EXT);
    x=0;
    print_buffer_flag = 1;
#int_ext1
void ext1_isr() //clock
  if(input(DATA_PIN))
    byte_in |= bit_mask;
  bit_mask = bit_mask << 1;
  if(bit_mask == 0x0200) //9 bits per word
    bit_mask = 0x0001;
    buffer[x] = byte_in;
    x++;
    byte_in = 0;
In main, the buffer is printed over rs232 to a PC. The data I've gotten back doesn't seem to be right. I've put the data signal and the enable signal on an oscilloscope. I can see that the first byte is 0x006A, or 106. But that number has never appeared in my data output from the PIC. Alot of the numbers are powers of 2.
Im using a PIC25j10 with a 9.216MHz crystal, using the PLL mode to run at 36.864MHz. The lcd clock signal has a frequency of 100kHz. Is this too fast for my code? How can I calculate how long 1 iteration of my ext1 isr takes?
PostPosted: Sat Aug 09, 2008 2:34 pm     Reply with quote
Post your variable declarations for that code.
PostPosted: Sat Aug 09, 2008 4:07 pm     Reply with quote
This is the entire code
#include<18f25j10.h>
#fuses H4_SW, NOPROTECT, NOWDT
#define   SYSTEM_CLOCK  36864000
#use delay( clock = SYSTEM_CLOCK )
#use rs232( xmit=PIN_C6,  baud=9600, bits=8, parity=N )
#define N 64
#define DATA_PIN PIN_A0
int1 int_edge_flag,print_buffer_flag;
int16 bit_mask=0x0001;
int16 byte_in;
int16 buffer[N];
int16 x,y,z;
#int_ext
void ext_isr() //enable triggers ext0
    int_edge_flag = 0;
    int_edge_flag = 1;
    x=0;
#int_ext1
void ext1_isr() //clock triggers ext1
  if(input(DATA_PIN))
  if(bit_mask == 0x0200) //9 bits per byte
    bit_mask = 0x0001;
    x++;
    byte_in = 0;
void main ()
   setup_oscillator(OSC_PLL_ON) ;
   for(y=0;y<N;y++)
     buffer[y] = 0;
   enable_interrupts(INT_EXT);
   ext_int_edge(0, H_TO_L);   //enable is active low
   ext_int_edge(1, L_TO_H);   //clock is active high
   int_edge_flag = 1;         //flag to signify ext0 trigger edge  H_TO_L is 1, L_TO_H is 0
   while (TRUE)
     if(print_buffer_flag)
       for(y=0;y<N;y++)
         printf("\n\r %Lu",buffer[y]);
       print_buffer_flag = 0;
PostPosted: Sun Aug 10, 2008 2:46 am     Reply with quote
First comment is that this doesn't sound at all like 'I2C'. It sounds as if this is perhaps a logic based synchronous serial (more like the PS/2 protocol). Now, really the only answer is going to be to find out what it really is!....
However, if it is a synchronous clock based protocol, then I'd suggest cutting the interrupts to just one. The problem is that 100K, while not 'too fast' for the PIC to handle, _does_ require careful thought. If you can work out which edge of the clock corresponds to stable data, have just one interrupt, from this edge. Interrupts, cost a lot of time. If you are interrupting on both edges of something potentially changing at 100KHz, you have just 5uSec between these changes. The PIC won't handle this.
I'd suggest then, that you actually need to stay inside the data handler, when the active clock edge is received. Add a 'timeout', so if you miss an edge, the code will recover.
Though this goes against the 'keep interrupts as short as possible' mantra, at this sort of data rate, it is going to be needed.
So (In a sort of 'theoretical' form):
#intxxxxx
void active_clock_edge(void) {
   int16 data=0;
   int16 mask=1;
   int8 ctr;
   int1 temp;
   //Read the data ASAP
   tmp=input_bit(DATA_BIT);
   //Now set a timer, to timeout after perhaps 1.5 character times
   set_timerx(count);
   clear_interrupts(INT_TIMERX);
   //Program a bit statement, to access the interrupt flag for this timer
   //as TimerxIF
   if (tmp) data|=mask; //Put the first bit into the result
   for (ctr=0;ctr<8;ctr++) {
      //Now 8 more bits to handle
      while (input_bit(CLOCK_BIT)==ACTIVE) {
          if (TimerxIF) return; //Timeout if interrupt flag is set
      //Now wait for the clock to go active again
      while (input_bit(CLOCK_BIT)!=ACTIVE) {
          if (TimerxIF) return; //Again timeout
      mask<<=1; //setup the mask, and this rotation, according to the
      //order the bits arrive
      if (input_bit(DATA_BIT)) data|=mask;
   //Here set a flag that 'data' has arrived, and copy the received character
   //to a temporary store.
Now, you will have to work out what timer to use for the timeout, what edge to set the interrupt to, and what levels are the 'active' ones etc., and generate the real code, but this is the sort of approach needed to receive such a data stream.
PostPosted: Sun Aug 10, 2008 12:33 pm     Reply with quote
Actually, the ext0 is for the enable. ext1 is for the clock. The enable goes low for a couple of milliseconds, during which the clock and data line do their thing. I'm only changing the trigger edge for the enable, to know when the packet starts and ends.
The clocks interrupt is always positive edge triggered. The clock is a 100kHz signal, but its duty cycle is probably only 20% or less. The rising edge of the clock occurs in the center of a data bit.
There is also a delay between groupings of 9 clocks. I don't have the scope in front of me right now, but Im pretty certain this delay is longer than 90 us, the duration of one byte.
But what you've laid out makes sense.
//as TimerxIF
So for timer0, I would do some thing like this?
#define TIMER0IF bit_test(INTCON,5)
PostPosted: Sun Aug 10, 2008 2:13 pm     Reply with quote
This is what the first byte looks like on a scope
   ___
ENA   |____________________________________________ ....
CLK_______|___|___|___|___|___|___|___|___|________ ....
             ___     ___     _______
DAT_________|   |___|   |___|       |______________ ....
          0   1   0   1   0   1   1   0   0
001101010 = 0x006A
PostPosted: Sun Aug 10, 2008 3:10 pm     Reply with quote
No, I'd just define a bit.
so:
#bit TIMER0IF=INTCON.5
I'd use the rising edge of the clock then, to sample ASAP. Given the delays getting into the interrupt, it may still be borderline.
PostPosted: Sun Aug 10, 2008 8:03 pm     Reply with quote
How can you calculate the total propagation delay of the interrupt, meaning the time between the signal changing, and the interrupt service routine starting?
PostPosted: Mon Aug 11, 2008 2:40 am     Reply with quote
Count the instructions.
Normally the instruction at address 8, executes, a maximum of 14.25 clocks after the event. You then have the code to save the internal registers, which is slightly 'worse' on a 18chip, but then reduced a little by the presence of the RETFIE 1 instruction, which allows three registers to be skipped. Typically 15 double length instructions. Then the interrupt bit itself is tested, and it's enable, usually another 5 instruction times, before you arrive at the handler. So a total of about 155 clock cycles. Equivalent to just under 40 instruction times. With your clock, about 4.2uSec.
As you can see, this should be 'OK' with your clocks, but it doesn't leave a lot of spare time, especially if you leave the interrupt and return (it takes about as long to come out again), and code in the interrupt itself can take a surprising time.
