PIC16F887 #int_rda problem.
akshaymathur39
PostPosted: Sat Aug 09, 2008 9:22 pm     Reply with quote
Hello Friends,
I have written a simple code of using USART receive interrupt system. When the data is received, it jumps to the interrupt function and blinks the led in the function loop with less delay. As soon as it comes out of the interrupt blinking loop, it again enters the same loop detecting interrupt. Its like it keep running in the interrupt loop. I doubt that may be interrupt flag is not cleared when it jumps back to main loop. Please have a look at the code.
#include "C:\Documents and Settings\Akshay Mathur\Desktop\RS232 test\rs232.h"
int i=0,j;
byte buf[3];
#int_RDA
void  RDA_isr(void)
   for(j=0;j<10;j++){output_low(PIN_C0);delay_ms(45);output_high(PIN_C0);delay_ms(45);}
   setup_adc_ports(sAN0|sAN1|sAN2|sAN3|sAN4|sAN5|sAN6|sAN7|VSS_VDD);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
   enable_interrupts(INT_RDA);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
   // TODO: USER CODE!!
   while(TRUE){
   output_low(PIN_C0);
Header details:
#include <16F887.h>
#device adc=10
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES BORV40                   //Brownout reset at 4.0V
#use delay(clock=8000000)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
PostPosted: Sat Aug 09, 2008 10:40 pm     Reply with quote
#int_RDA
void RDA_isr(void)
for(j=0;j<10;j++)
output_low(PIN_C0);
delay_ms(45);
delay_ms(45);
The clue is in the 16F8887 data sheet:
12.1.2.3 Receive Interrupts
The RCIF interrupt flag bit of the PIR1 register is set
whenever the EUSART receiver is enabled and there is
an unread character in the receive FIFO. The RCIF
interrupt flag bit is read-only, it cannot be set or cleared
by software.
RCIF interrupts are enabled by setting the following
bits:
• RCIE interrupt enable bit of the PIE1 register
• PEIE peripheral interrupt enable bit of the
INTCON register
• GIE global interrupt enable bit of the INTCON
register
The RCIF interrupt flag bit will be set when there is an
unread character in the FIFO, regardless of the state of
interrupt enable bits.
Question: What should you do inside the #int_rda isr to
remove this condition ?
Question #2: If you have massive delays inside your #int_rda isr,
what happens when characters keep coming in, but your isr can't do
anything about them, because it's stuck doing the massive delays ?
