problem with string
ROBOTICAR
problem with string
PostPosted: Sat Aug 09, 2008 5:12 am     Reply with quote
Hi ALL
How can I empty the string? for example I define J[40] and with serial communication (RS232) get 40 characters. I want to keep on this loop and I need to make J empty. How can I do that?
ROBOTICAR
PostPosted: Sat Aug 09, 2008 10:55 am     Reply with quote
and another question.
How can I change 3256.212 into 3256212 ??
PostPosted: Sat Aug 09, 2008 7:44 pm     Reply with quote
memset(J, 0, 40);
you will need to include string.h to use memset.
You could also make a for loop
for(x=0;x<40;x++)
  J[x] = 0;
As for your second question, you need to make sure that the variable storing the second number will be of a large enough type. An unsigned 32 bit integer will do the trick. Then just multiply by 100.
PostPosted: Sat Aug 09, 2008 7:45 pm     Reply with quote
Sorry, I meant 1000
SherpaDoug
Re: problem with string
PostPosted: Sun Aug 10, 2008 5:03 am     Reply with quote
ROBOTICAR wrote:
Hi ALL
First you must define "empty". In C strings are usually terminated with a null (0x00). So if you make the first byte of the string null the string will be empty. If this is a serial buffer with head and tail pointers you can make it empty by setting the two pointers to the same address.
