simat
| WDT Sleep problem with loop |
Posted: Wed Aug 06, 2008 10:50 am |
I'm having a weird problem, I think it may have something to do with a stack getting full, the code below prints 'POL' three times before getting stuck in a do while(true) loop used in MAIN (the code is part of main) How are variables handling during sleeping.
If I don't check the value of radiostatus in IF statement at the top of the code then everything is fine. radiostatus is set to 2 after an event.
Basically after sleep the if(cycle > 1 && radiostatus > 1) doesn't execute even though the conditions are met.
It also looks like the interrupts stop working, INT_RDA, INT_TBE, INT_TIMER1
Any ideas ?
Cheers
Simon.
//NEAR the bottom of MAIN()
{ // no sleep until radiostatus is 2
delay_ms(10); // Enought time for xmit of 5 bytes at 19200 BPS
cycle = 2; // for some weird reason we need this else it gets stuck in sleep
while (cycle > 0) {
sleep();
delay_cycles(1);
cycle--;
strcpy(m_buffer,"POL");
bprintf(m_buffer); // Print POL to serial port.
cycle++; // For above WDT control and Main loop control whilst out of sleep,
// we use this variable to count up as well as down
restart_wdt(); // feed the dog - resets PIC only if we're not sleep and the dog doesn't get fed.
//back to top of MAIN() |
Posted: Wed Aug 06, 2008 5:53 pm |
Post a complete test program. Post the #include, #fuses, and
#use delay() statements. Add the minimum amount of additional code
to demontrate the problem. For example, if you can show the problem
by adding a very small #int_rda routine (and no other interrupt routines)
then do so. The code must be compilable with no errors, and it must
show the problem when it's run on a PIC. (Test it first).
Make it short. Don't put in any unnecessary lines of code. In other words,
don't setup the ADC ports, etc., if they are not needed to demonstrate
the problem.
Also post your compiler version. |
Wayne_
Posted: Thu Aug 07, 2008 8:52 am |
Having to add
Implies that at some point cycle is much larger when entering this routine causing a delay of
cycles * WDT_timeout * delay_cycles(1)
If cycles is a 16 bit value and is at it's max 65535 and your WDT is set to 4 sec then your loop will take 65535 * 4 * delay_cycles(1) (sec) to execute!
at least 72 hours.
NOW you see why we need more information to help you with this problem  |
Wayne_
Having to add
at least 72 hours.
simat
Posted: Thu Aug 07, 2008 9:34 am |
Hi, heres some more code, compiler is 4.057
#include <16f88.h>
#include <string.h>
#fuses HS,WDT,NOPROTECT,PUT,NOBROWNOUT,NOLVP
#use rs232(baud=19200, xmit=PIN_B5, rcv=PIN_B2, parity=N, bits=8, stop=1, ERRORS, UART) // 16F88
#define DQ PIN_B0 // One Wire Bus pin assignment
#define PWR_EN PIN_B3 // One Wire PWR pin assignment
#define JN5139_EN PIN_B4 // JN5139 Module enable
#define JN5139_WAKE PIN_B1 // JN5139 Interrupt to wakeup from sleep
#define DEBUG PIN_A1 // Debug LED
#define uint8 char
#define uint16 long
// Global Variables
uint8 crc8 = 0;
uint16 crc16 = 0;
uint8 ROMbit[8];
uint8 lastDiscrep = 0;
short doneFlag = 0;
uint8 FoundROM[9][8];
uint8 maxDevices = 10;
uint8 numROMs = 0;
uint8 message[4];
uint8 NTU[8];
uint8 tickCount = 0;
#define r_BUFFER_SIZE 32 // Receive Buffer
BYTE r_buffer[r_BUFFER_SIZE];
BYTE r_next_in = 0;
BYTE r_next_out = 0;
#define t_BUFFER_SIZE 16 // Transmit Buffer
BYTE t_buffer[t_BUFFER_SIZE];
BYTE t_next_in = 0;
BYTE t_next_out = 0;
#define m_BUFFER_SIZE 64
uint8 m_buffer[m_BUFFER_SIZE];
uint8 m_bufferPtr = 0;
#int_TBE
void t_serial_isr(void)
putc(t_buffer[t_next_out]);
t_next_out = (t_next_out + 1) % t_BUFFER_SIZE;
if (t_next_in == t_next_out)
disable_interrupts(int_tbe);
void bputc(char c)
short restart;
int ni;
restart = t_next_in == t_next_out;
t_buffer[t_next_in] = c;
ni = (t_next_in + 1) % t_BUFFER_SIZE;
while (ni == t_next_out)
enable_interrupts(int_tbe);
t_next_in = ni;
if (restart)
#int_RDA
void r_serial_isr(void)
BYTE t;
r_buffer[r_next_in] = getc();
t=r_next_in;
r_next_in = (r_next_in + 1) % r_BUFFER_SIZE;
if(r_next_in == r_next_out)
r_next_in = t;
#define bkbhit (r_next_in != r_next_out)
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c = r_buffer[r_next_out];
r_next_out = (r_next_out+1) % r_BUFFER_SIZE;
return(c);
#int_TIMER1
void t_ticker(void) // For timing events, tickCount increments every 100ms @ 8MHz CLK - depends on T1 setup.
tickCount++;
uint8 radiostatus = 0;
uint8 cycle = 0;
disable_interrupts(GLOBAL);
disable_interrupts(INT_RDA);
disable_interrupts(INT_TIMER1);
setup_wdt(WDT_2304MS); // Setup WDT for 2.3 seconds
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); // Timer 1 for awake time monitoring
restart_wdt();
enable_interrupts(INT_RDA);
set_timer1(0);
tickCount = 0;
do // Main Program Loop
output_toggle(DEBUG); // Toggle LED to indicate life.
if(bkbhit) // We have data to decode
m_buffer[m_bufferPtr]=(bgetc());
m_bufferPtr++;
// parse m_buffer section
// do operations on 1-wire devices.
if(cycle > 1 && radiostatus > 1) // FYI - cycle incremented below
cycle = 2; // for some weird reason we need this.
while (cycle > 0) {
sleep();
delay_cycles(1);
cycle--;
tickCount = 0;
//strcpy(m_buffer,"POL");
//bprintf(m_buffer);
bputc(64); // print @ just for this test example still use INT_RBE interrupt.
cycle++; // For above WDT control and Main loop control whilst out of sleep.
restart_wdt();
} while (TRUE);
simat
Posted: Thu Aug 07, 2008 9:35 am |
#include <16f88.h>
#include <string.h>
#define uint8 char
#define uint16 long
// Global Variables
uint8 crc8 = 0;
uint16 crc16 = 0;
uint8 ROMbit[8];
short doneFlag = 0;
uint8 numROMs = 0;
uint8 message[4];
uint8 NTU[8];
BYTE r_next_in = 0;
BYTE t_next_in = 0;
#int_TBE
void bputc(char c)
short restart;
int ni;
t_next_in = ni;
if (restart)
#int_RDA
BYTE t;
t=r_next_in;
r_next_in = t;
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
return(c);
#int_TIMER1
tickCount++;
uint8 cycle = 0;
restart_wdt();
set_timer1(0);
tickCount = 0;
m_bufferPtr++;
while (cycle > 0) {
sleep();
delay_cycles(1);
cycle--;
tickCount = 0;
restart_wdt();
} while (TRUE);
simat
Posted: Thu Aug 07, 2008 9:36 am |
#include <16f88.h>
#include <string.h>
#define uint8 char
#define uint16 long
// Global Variables
uint8 crc8 = 0;
uint16 crc16 = 0;
uint8 ROMbit[8];
short doneFlag = 0;
uint8 numROMs = 0;
uint8 message[4];
uint8 NTU[8];
BYTE r_next_in = 0;
BYTE t_next_in = 0;
#int_TBE
void bputc(char c)
short restart;
int ni;
t_next_in = ni;
if (restart)
#int_RDA
BYTE t;
t=r_next_in;
r_next_in = t;
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
return(c);
#int_TIMER1
tickCount++;
uint8 cycle = 0;
restart_wdt();
set_timer1(0);
tickCount = 0;
m_bufferPtr++;
while (cycle > 0) {
sleep();
delay_cycles(1);
cycle--;
tickCount = 0;
restart_wdt();
} while (TRUE);
Posted: Thu Aug 07, 2008 9:38 am |
#include <16f88.h>
#include <string.h>
#define uint8 char
#define uint16 long
// Global Variables
uint8 crc8 = 0;
uint16 crc16 = 0;
uint8 ROMbit[8];
short doneFlag = 0;
uint8 numROMs = 0;
uint8 message[4];
uint8 NTU[8];
BYTE r_next_in = 0;
BYTE t_next_in = 0;
#int_TBE
void bputc(char c)
short restart;
int ni;
t_next_in = ni;
if (restart)
#int_RDA
BYTE t;
t=r_next_in;
r_next_in = t;
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
return(c);
#int_TIMER1
tickCount++;
uint8 cycle = 0;
restart_wdt();
set_timer1(0);
tickCount = 0;
m_bufferPtr++;
while (cycle > 0) {
sleep();
delay_cycles(1);
cycle--;
tickCount = 0;
restart_wdt();
} while (TRUE);
Posted: Thu Aug 07, 2008 9:39 am |
#include <16f88.h>
#include <string.h>
#define uint8 char
#define uint16 long
// Global Variables
uint8 crc8 = 0;
uint16 crc16 = 0;
uint8 ROMbit[8];
short doneFlag = 0;
uint8 numROMs = 0;
uint8 message[4];
uint8 NTU[8];
BYTE r_next_in = 0;
BYTE t_next_in = 0;
#int_TBE
void bputc(char c)
short restart;
int ni;
t_next_in = ni;
if (restart)
#int_RDA
BYTE t;
t=r_next_in;
r_next_in = t;
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
return(c);
#int_TIMER1
tickCount++;
uint8 cycle = 0;
restart_wdt();
set_timer1(0);
tickCount = 0;
m_bufferPtr++;
while (cycle > 0) {
sleep();
delay_cycles(1);
cycle--;
tickCount = 0;
restart_wdt();
} while (TRUE);
simat
Posted: Thu Aug 07, 2008 9:45 am |
| can a moderator please clean up this reply, the BBS has got a bit screwed and keeps telling me DEBUG MODE post failed. |
Wayne_
Posted: Thu Aug 07, 2008 9:57 am |
It will never enter
because radiostatus is initialised to 0 and never changes!
Unless I missed something  |
simat
Posted: Thu Aug 07, 2008 9:59 am |
cycle increments at near the bottom of the code.
I'm using the variable twice, for count up to enter the sleep section and then counting down to zero to exit the sleep section. |
simat
Posted: Thu Aug 07, 2008 10:02 am |
| derr I'm not being to bright am I, radiostatus is set to 2 in MAIN but I've missed that out, sorry. |
Wayne_
Posted: Thu Aug 07, 2008 10:05 am |
Yes BUT radiostatus does not change!
You if statement relies on radiostatus being > 0!
That is not entirely true. You have a bug in your code.
You do not check for m_buffer overrun, When this happens
m_bufferPtr++;
and m_bufferPtr > m_BUFFER_SIZE then memory corruption will occur.
As radiostatus is almost next inline for the definitions then this is most certainly being corrupted causing you code to enter the if statement, BUT as this is random cycle will now be a random value causing your code to remain in the while loop for sometime. |
simat
Posted: Thu Aug 07, 2008 10:11 am |
Hi, but surely m_bufferPtr will just overflow back to zero after hit 255 ?
Also m_buffer is 64 bytes large and we don't put that much data in each time, after the code is parse (not shown) we reset m_bufferPtr to zero ready for next time. |
