16F88 and LCD
nuno12345
16F88 and LCD
PostPosted: Wed Aug 06, 2008 10:28 pm     Reply with quote
Hi again, I cant get my LCD to work :/
LCD: 16x2 LCD Module White Characters with Blue Backlight HD44780
PIC: 16F88 I/P
CODE:
#include <16F88.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#include "flex_lcd.c"
lcd_init();
lcd_putc("\fHello World");
PROGRAMMER: JDM Programmer (bought)
PROBLEM: The LCD just "lights" it doesnt show anything...once I got it to show the "end blinking square" but I cant get it anymore :/
Thanks ;)
PostPosted: Wed Aug 06, 2008 10:38 pm     Reply with quote
Post the list of connections between the LCD and the PIC.
Also post the other connections that you have to the LCD, such as
the contrast circuit.
nuno12345
PostPosted: Wed Aug 06, 2008 11:10 pm     Reply with quote
I have them like this:
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_A1
#define LCD_RS    PIN_A3
#define LCD_RW    PIN_A2
I have 2 extra PIN's on the LCD for backlight, positive and negative, the backlight lights ON...
The VEE PIN I try to connect to GND VCC, used a 10k resistor...
PostPosted: Thu Aug 07, 2008 12:52 am     Reply with quote
1. Post the manufacturer and part number of the LCD.
2. Post your compiler version.
nuno12345
PostPosted: Thu Aug 07, 2008 8:42 am     Reply with quote
CCS: 4.074
LCD: JHD 162A (I think its from Hitachi)
PostPosted: Thu Aug 07, 2008 11:36 am     Reply with quote
I tested your program with a 16F88 on a PicDem2-Plus board, with your
connections, and with your version of the compiler. It worked OK.
I think the problem is that your connections to the LCD are probably
not correct. You should check them again.
nuno12345
PostPosted: Thu Aug 07, 2008 11:42 am     Reply with quote
I did check them :/
It works for me in proteus too but not on my breadboard :/
nuno12345
PostPosted: Thu Aug 07, 2008 12:49 pm     Reply with quote
Finnaly working, voltage problem...in desperate I got closer to the pc monitor then I watched the LCD and there was the text, but I could barely notice it...I increased the voltage and voila! lol
Thanks PCM, your the man ;)
