Rotate function in c
stewc
PostPosted: Tue Aug 05, 2008 3:26 am     Reply with quote
This may be a bit off topic but I have seen this bit of code from an I2C function and I dont understand what it does.
for(x=0; x<8; x++) {
    d <<= 1;
    do {
      SCL = 1;
I dont understand the syntax of the "<<="
PostPosted: Tue Aug 05, 2008 3:59 am     Reply with quote
<<, is a 'standard' C operator. Just like +,-, * etc..
It is one of the family of 'bitwise' operators available in C. It is a _shift_ (not a 'rotate' as in your question), and shifts the left hand operand left, the number of bits specified in the right hand operand, filling the vacated bits with zeros. So:
int8 a;
a=2;
a = a<<2;
Will put back into 'a', it's own value left shifted twice.
Lot's of caveats, since you need to know the bit order on the processor involved. On the PIC, left shifting, is equivalent to multiplying by 2, so shifting twice, gives the equivalent to multiplying by 4. So 'a' ends up as 8.
Now, in your example, it has been used in the C 'operand=' construct, which allows you to leave out the left hand operand, and the command shifts by 1.
There is also a >> for right shifting.
It is standard C, and any text book should give details.
stewc
PostPosted: Tue Aug 05, 2008 4:45 am     Reply with quote
Thanks for your reply
So basically it is eqivalent to
d = d << 1
Very Happy
PostPosted: Tue Aug 05, 2008 6:21 am     Reply with quote
Exactly.
I thought you didn't understand the usage of <<, rather than the 'shorthand'.
