reading flash memory one byte at a time.
x!nDy
PostPosted: Tue Jul 29, 2008 8:47 pm     Reply with quote
Hi everyone, i am saving data in flash memory and these data are variable in length and are separated by a delimiter (*). So what i want to do is try to read flash one bit at a time and look for the (*). If i found an * then i would print the word. But i cant seem to get it to work. Here is my code.
FlashLoopRead=FlashStartAddress; //FlashLoopRead receives the last address in flash holding a certain value.
FlashStartAddress = FlashReadAddress; // FlashStartAddress receives the first address in flash holding a certain value
disable_interrupts(GLOBAL);
ii=0;
do
   read_program_memory(FlashStartAddress, temp1, 1); // temp1 is char
   msg[ii] = temp1; // msg[ii] is an array with a length of 80
   if (msg[ii]=='*')
      *(msg[ii])='\0';
      FlashStartAddress = FlashStartAddress + ii;
      fprintf(PC,"\n%s\n",msg);
      ii=0;
      justOnce=True; // justOnce is a boolean
   if (!justOnce)
      ii++;
   justOnce=false;
}while(FlashStartAddress<=FlashLoopRead);
So, if the contents of my flash memory is HELLO*WORLD!*, it would print HELLO
WORLD!
please help.. thanks in advance..
Indy31
PostPosted: Wed Jul 30, 2008 3:37 am     Reply with quote
Bug 1: read_program_memory() should be passed an address for storing the data read from flash. change:
to:
read_program_memory(FlashStartAddress, &temp1, 1); // temp1 is char
Bug 2:
*(msg[ii])='\0';
should have been:
*(&msg[ii])='\0';
or
msg[ii]='\0';
General note 1: indirect addressing on the PIC is very inefficient and requires a lot of instructions. You can save memory and increase performance by minimizing array accesses. instead of:
if (msg[ii]=='*')
it is more efficient to write:
if (temp1=='*')
General note 2: Using 'justOnce' variables make your code difficult to understand. Instead of an if-if combination your code is faster and easier to understand if you use an if-else construction.
Regarding all above, here is my suggested code:
ii=0;
do
   if (temp1=='*')
      msg[ii]='\0';
      ii=0;
      ii++;
x!nDy
PostPosted: Wed Jul 30, 2008 9:09 pm     Reply with quote
hi.. thanks for the reply and explanation.. i really appreciate it.. however, when i try to use your code and try to look at the value of temp1, all it prints is 0.. can you tell me how this happened? here is my code:
ii=0;
do
   fprintf(PC,"temp1 = %c\n",temp1); // prints value of temp1
   if (temp1=='*')
      msg[ii]='\0';
      ii=0;
      ii++;
RLScott
PostPosted: Thu Jul 31, 2008 10:08 am     Reply with quote
ii=0;
do
   if (temp1=='*')
      msg[ii]='\0';
      ii=0;
      ii++;
You are not advancing FlashStartAddress when each character is read, so it seems that read_program_memory() will just read the same first byte over and over, and you will never get to the '*'. The msg[ii] = temp1 will eventually overflow the bounds of the msg[80] and trash some other memory and the program will crash. This will happen even if you did everything else right if the '*' is somehow absent. What did you see as a result of printout of temp1?
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
x!ndy
PostPosted: Thu Jul 31, 2008 8:23 pm     Reply with quote
you are right.. it was really stupid of me.. Embarassed it works fine now.. thanks..
