problem on 12F683
filjoa
problem on 12F683
PostPosted: Tue Jul 29, 2008 2:01 pm     Reply with quote
Hi
I try make a little example with this PIC12F683 with internal clock but it don't work...
#include <12F683.h>
#fuses NOWDT,INTRC_IO, NOCPD, NOPROTECT, MCLR, NOPUT, BROWNOUT, IESO, FCMEN
output_high(PIN_A0); //pin number 7
output_low(PIN_A0);
I have on PIN_A0 one LED.
some one can help me?
regards Wink
PostPosted: Tue Jul 29, 2008 2:25 pm     Reply with quote
Post your compiler version. It's a 4-digit number in this format: x.xxx
It's given at the top of the .LST file. The .LST file is in your project directory.
PostPosted: Tue Jul 29, 2008 2:48 pm     Reply with quote
Obvious comments apply though:
Hopefully you have a pull up on the MCLR input.
Series resistor to the LED.
filjoa
PostPosted: Tue Jul 29, 2008 4:06 pm     Reply with quote
Hi
yes, I dont remember resistor on MCLR :S and other problem stay on the LED, it stay dead..
now all work, thanks...
Charlie U
PostPosted: Tue Jul 29, 2008 6:05 pm     Reply with quote
If I am not mistaken, the GPIO pins 0-3 default to analog inputs. They must be specifically set to digital I/O with a set up function. I don't have access to my compiler just now, but look at the setup functions in the help files and the appropriate parameters in the 12F683.h files.
