Conditional Expression Operator ?: error
rhaguiuda
PostPosted: Fri Jul 25, 2008 8:50 am     Reply with quote
I can't understand why this code generates an error:
(input(PIN_A1)) ? i = 1 : i = 0;
Error: Line 214(23,24): Expecting :
My compiler version is: 4.017
Can someone help me?
Thanks!!!
PostPosted: Fri Jul 25, 2008 9:24 am     Reply with quote
You syntax is wrong, it should be:
 i = (input(PIN_A1)) ? 1 : 0;
Several companies I've worked for don't allow the ?: construction because it often leads to difficult to read code and does not reduce the size of the generated code. The following code fragment does the same and is easier to read:
if (input(PIN_A1))
  i = 1;
  i = 0;
or in this particular case can even be optimized to:
i = input(PIN_A1);
As a side note: the compiler versions before v4.030 contain large numbers of bugs and I wouldn't use them.
rhaguiuda
PostPosted: Fri Jul 25, 2008 11:04 am     Reply with quote
Ckielstra, thanks very much.
The code works great now!
