m@rie Guest
| ccp help.. |
Posted: Thu Jul 24, 2008 2:39 am |
is something wrong with my code? i just place a waveform generator in PIN_C1. what i want is to display the no. of pulses that the generator generates. please help..
#include <18F4525.h>
#device ICD=TRUE
#device PASS_STRINGS = IN_RAM //this is needed so that you can directly use strcmp even if one
//parameter is not a variabe
//strcmp(mystr,"OK") --> this will still work..
#FUSES PUT //Power Up Timer
#FUSES NOIESO //NO Internal External Switch Over mode enabled
#FUSES NOPBADEN //NO PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_D4, rcv=PIN_D5, stream=PC)
int16 findata=0;
void main(){
int msgNumxx=0;
setup_ccp2(CCP_CAPTURE_RE);
clear_interrupt(INT_CCP2);
enable_interrupts(INT_CCP2);
do{
fprintf(PC,"findata = %li\n",findata);
}while(1);
#int_CCP2
void CCP2_isr()
finData++;
Posted: Thu Jul 24, 2008 4:22 am |
Since this is a related question to an earlier thread you launched, I'd say you should have added this question to the _same thread_. This is better for people in the future, since they can look for a particular problem, and find all the likely solutions in one place,instead of scattered all over the group...
The answer here, is almost certainly CCP2C1. You need this fuse set, to use pin C1, as the CCP input.
