kender
Can’t assign pointer to a library function |
Posted: Wed Jul 23, 2008 6:09 am |
Colleagues,
I was trying to make a generic set_pwmX_duty(x, duty) function with a table of pointers: {set_pwm1_duty, set_pwm2_duty, …}. Unfortunately, I’m getting a compile time error:
typedef void (*fptypeSetPWMDuty)(int16 iPWM); // pointer to the set_pwm12345_duty() function
typedef struct // structure describing a channel
fptypeSetPWMDuty fpSetPWMDuty; // pointer to the set_pwmX_duty() function
g_sChannels[0].fpSetPWMDuty = set_pwm1_duty; // compile-time error: Undefined identifier set_pwm1_duty
set_pwm1_duty(255); // at the same time, this line of dummy code compiles just fine
PCWH 4.071 PIC18F4525
Cheers
- Nick _________________ Read the label, before opening a can of worms. |
Posted: Wed Jul 23, 2008 8:03 am |
You will almost certainly find that set_pwmX_duty, is not really a 'function', but possibly a simple macro expansion. You will almost certainly have to put it into a 'wrapper' function, to allow a pointer to be generated.
Simple operations like this, which only transfer bytes into specific registers, with some basic manipulation on the way, are almost invariably not functions.
