helping me in coding 4x4 |
Posted: Sat Jul 19, 2008 8:50 pm |
//// KBDD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
////////////////// The following defines the keypad layout on port D
// Un-comment the following define to use port B
// #define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#if defined(__PCH__)
//#if defined use_portb_kbd
#byte kbd = 0xF81 // This puts the entire structure
#else
#byte kbd = 0xF83// This puts the entire structure
#else
//#byte kbd = 6 // on to port B (at address 6)
//#else
#byte kbd = 8 // on to port D (at address 8)
// #define set_tris_kbd(x) set_tris_b(x)
//#else
#define set_tris_kbd(x) set_tris_d(x)
//#endif
#include <18f4550.h>
#fuses NOLVP,HS,.....
//Keypad connection: (for example column 0 is B2)
// Bx:
/*#ifdef blue_keypad ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
//#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define COL3 (1 << 8)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2|COL3)
// Keypad layout:
int const KEYS[4][4] =
{{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}};
#define KBD_DEBOUNCE_FACTOR 33
void kbd_init()
//set_tris_b(0xF0);
//output_b(0xF0);
port_b_pullups(true);
short int ROW_HIGH()
if(input (ROW0) || input (ROW1) || input (ROW2) || input (ROW3))
return (1);
return (0);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
switch (col)
case 0:
output_high(col0);
output_low(col1);
output_low(col2);
output_low(col3);
case 1:
output_low(col0);
output_high(col1);
output_low(col2);
output_low(col3);
case 2:
output_low(col0);
output_low(col1);
output_high(col2);
output_low(col3);
case 3:
output_low(col0);
output_low(col1);
output_low(col2);
output_high(col3);
if(kbd_down)
if(!ROW_HIGH())
kbd_down=false;
kchar=last_key;
last_key='\0';
if(ROW_HIGH())
if(input (row0))
row=0;
else if(input (row1))
row=1;
else if(input (row2))
row=2;
else if(input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
++col;
if(col==4)
col=0;
kbd_call_count=0;
return(kchar);
void main(){
unsigned char k;
k=kbd_getc();
if(k!=0)
if(k=='*')
output_high(PIN_B0);
output_low(PIN_B0);
Is my main correct? I just want to try on a led when i press a key like '*'
but it cant work.
Please help. |
treitmey
Posted: Mon Jul 21, 2008 8:29 am |
Quote: | No other use, reproduction or distribution is permitted without written permission. |
Remove the post of the copyrighted code. Everyone that has this compiler also has access to this file. Just reference it(#include it) don't show it. |
treitmey
Posted: Mon Jul 21, 2008 8:56 am |
CCS Rev3.249 Pin D4 and D5 on PICDEM2 plus at 10Mhz
Code: | #include <16f877.h>
#device *=16
#use delay(clock=10000000)
#fuses hs,nowdt,noprotect,nolvp//we have a wdt now
#use rs232(baud=19200,xmit=PIN_E2,invert,stream=DEBUG,disable_ints)
#case
#zero_ram
#include "kbd.c"
unsigned char k;
fprintf(DEBUG,"start\n\r");
kbd_init();
k=kbd_getc();
if(k=='*')
fprintf(DEBUG,"got it\n\r");
delay_ms(2000);
output_low(PIN_B0);
