how to pass a string to function
vijay s
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Thu Jul 17, 2008 6:20 am     Reply with quote
i need a help in passing a string to function..
in my application i'm using usart to send a string continuosly.
for ex..void usart(int *a); //function declaration
while(*a)
putc(*a++);
function call
usart("hello world");
it shows a error "attempting to create a pointer for constant"
but i can able to do this coding in other cross compilers like hitech.. how to solve this
with regards
vijay s
andrewg
PostPosted: Thu Jul 17, 2008 7:20 am     Reply with quote
CCS puts strings into ROM, while pointers only point into RAM. I know there are some options to force constants into RAM, but I'm not very familiar with them. However, I do know that CCS supports a language extension where strings are automatically passed character-by-character to functions, so:
void usart (int a)
  putc(a);
or even simply:
putc("hello world");
should do what you want.
Andrew
PostPosted: Thu Jul 17, 2008 11:40 am     Reply with quote
If you use the following #device statement, then you can do it:
#device PASS_STRINGS=IN_RAM
See the post for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=34682&start=4
PostPosted: Fri Aug 01, 2008 8:10 am     Reply with quote
i want to send a starting and ending characters.
so i wrote a method
void mySend(char string)
   putc(0x3A);  // inform that this is the starting
   putc(string);
   putc(0x0D);   //    inform that this is the end
can called it like
mySend("hello");
the responce i got is
:h
:e
:l
:l
:o
but what i wanted is
:hello
it seems like the function has been called several times that is equal to the number of characters in the parameter.
how can get what i want?
PostPosted: Fri Aug 01, 2008 10:23 am     Reply with quote
You need to read the CCS manual. There is a function that accepts
a pointer to a string, but it's not putc(). Please read the manual.
Also, please follow the links in previous posts. If you follow the link
in my previous post, you will find an example.
