nuno12345
16F628A RX TX wirelessly |
Posted: Wed Jul 16, 2008 7:23 pm |
Hi all, I got a WRL-07816 from sparkfun.
Now I'm trying to communicate wirelessly with the TX and RX.
My problem is:
I can communicate with the two, but I've to use a POT in the receiver and it has to be adjusted precisely, otherwise it wont work.
The receiver is always getting something (I know it has noise) but what can I do to make it work? The way I'm doing probably it will work here in the protoboard (I'm using one PIC to both transmit and receive) but when I get another PIC and use one to transmit and another one to receive probably it wont work, because the signal will get weaker as the distance increases, I thought that when I get my new PIC (16f88) I could use read_adc to get the voltage, this way it will work as a precise POT, but the signal strength still resides..
My code:
Code: | #include <16F628A.h>
#use delay (clock=4000000)
#fuses INTRC_IO, NOWDT, NOPUT, NOBROWNOUT, NOMCLR, NOLVP, NOPROTECT
void transmit()
output_high(PIN_A0);
output_low(PIN_A0);
void receive()
if (input(PIN_A1) == 1)
output_high(PIN_B0);
output_low(PIN_B0);
while (true)
transmit();
receive();
Anyone?
EDIT:
I forgot to mention that I have my receiver connected to PIN_A1 and transmitter to PIN_A0 |
arunb
RE: |
Posted: Wed Jul 16, 2008 10:56 pm |
You need to configure the UART on the mcu using the #uses rs232 directive.
Ex:
#use rs232(baud=4800,xmit=pin_b2, rcv=pin_b1,parity=n,bits=8)
thanks
arunb |
nuno12345
Posted: Thu Jul 17, 2008 8:31 am |
Can you give me some code I can work with please? |
nuno12345
Posted: Thu Jul 17, 2008 6:44 pm |
Ok, I looked at other examples and made this code:
#define WireTX PIN_B2 // <--------- C 6
#define WireRX PIN_B1
#use rs232(baud=2400,xmit=WireTX , rcv=WireRX ,ERRORS , STREAM=COM_A )
unsigned int8 data;
int1 flag=0;
#int_rda
void rd_isr(void)
disable_interrupts(INT_RDA); // Disable Serial Recieve Interrupt
disable_interrupts(GLOBAL); // Disable Global Interrupts
data= fgetc(COM_A);
if(data=='T')
flag=1;
enable_interrupts(INT_RDA);
void transmit()
if(input(PIN_A0)==0) //if button pressed
delay_ms(20);
fputc('T',COM_A);
delay_ms(20);
delay_ms(200); //delay some ms
void receive()
if(flag==1)
output_high(PIN_A1);
output_low(PIN_A1);
flag=0;
enable_interrupts(global);
enable_interrupts(int_rda);
transmit();
receive();
Thing is, my LED flashes randomly, but when I connect PIN_A0 to GND nothing happens, or it keeps flashing randomly, and when I connect PIN_A0 to VCC the LED shuts off.. |
nuno12345
Posted: Thu Jul 17, 2008 10:37 pm |
Got it to work thanks to the following thread
#use rs232(baud=1200,xmit=WireTX , rcv=WireRX)
unsigned int data;
#INT_RDA
rda_isr()
data = getc();
while(true)
if (input(PIN_A0) == 0)
putc('1'); //Repeat data out
output_high(WireTX);
delay_ms(300);
putc('2'); //Repeat data out
output_low(WireTX);
delay_ms(300);
if(data == '1')
output_low(PIN_A1);
else if(data == '2');
output_low(PIN_A1);
nuno12345
Posted: Fri Jul 18, 2008 5:02 am |
Actually its not working, if I disconnect my TX and RX the LED still does the same thing :/ |
