silentwol
Please help me get serial working |
Posted: Sun Jul 13, 2008 10:30 am |
I'm using a 16F88 (int osc) with the hardware UART (9600 buad) and a MAX232. Using v4.074 of the compiler. I can send data using printf.
The problem is that I can't seem to receive data. When I connect R1 of the MAX232 to RX of the pin, my voltmeter reads 0.1V between RX and GND. If I disconnect it and measure just R1, it reads 4.57V, my supply voltage. Also, if I measure the current with R1 is connected to RX, it's about 5 mA... which seems awfully high.
I'm guessing this is the problem, as RX should always be high when nothing is being received, right?
Any help greatly appreciated!
Here's he code:
#include <16F88.h>
#device adc=8
#FUSES NOBROWNOUT //No reset when brownout detected
#use delay(internal=8M)
#use rs232(uart1, baud=9600)
char c;
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ);
while(1<2)
output_high(pin_B0); //blink the LED:
delay_ms(250);
output_low(pin_B0);
delay_ms(250);
printf("getting next char:");
c = getc();
printf(c);
silentwol
Posted: Sun Jul 13, 2008 10:41 am |
Oh, one more thing. When I run this, it always outputs "getting next char:" twice and the LED flashes twice. I.e. it is doing two iterations of the loop. Could this be related at all? |
Posted: Sun Jul 13, 2008 11:00 am |
That's not the correct way to use printf() to display a character.
Research it and change it to the correct way. |
silentwol
Posted: Sun Jul 13, 2008 11:09 am |
Ah ok, fixed and changed to:
putc( getc() );
Still no joy though. Have I set up the UART properly? I've tried with the following line instead, but that also isn't working:
#use rs232(baud=9600,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8) |
Posted: Sun Jul 13, 2008 11:17 am |
Delete the setup_spi() statement. It's changing the TRIS on pin B2
to be an output pin.
This statement, put in by the Wizard, doesn't need to be there, and is
one of the biggest causes of problems. Delete it. |
silentwol
Posted: Mon Jul 14, 2008 2:40 pm |
Thanks very much, that's working now |
