hardware usart problem with pic 16f688
fbinotti
PostPosted: Wed Jul 09, 2008 9:41 am     Reply with quote
I can't use the hardware uart, with the FORCE_SW parameter the communication is good.
My pcwh version is: 4.062
#include <16F688.h>
#device adc=8
#FUSES PUT //Power Up Timer
#use delay(internal=4M)
//WORK.....
#use rs232(baud=2400,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=PC,FORCE_SW)
//DON'T WORK
//#use rs232(baud=2400,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=PC) //HARDWARE UART
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
while(true)
fprintf(PC,"Test 232\n\r");
Fabrizio Binotti
PostPosted: Mon Jul 14, 2008 7:15 am     Reply with quote
were you able to get the HW uart working? If not, post a reply and I can send you code I have used on the 16f688 using the HW uart.
guest1
PostPosted: Mon Jul 14, 2008 8:19 am     Reply with quote
Maybe you need to set the TX pin as an output. It's possible that the software UART code does this for you. Using the hardware you have to do it yourself.
fbinotti
PostPosted: Mon Jul 14, 2008 12:53 pm     Reply with quote
The problem was solved in
CCS PCM C Compiler, Version 4.076, 41428
Thank you.
Fabrizio Binotti
