Any other way
Goto page 1, 2  Next
pdl
Any other way
PostPosted: Sun Jul 13, 2008 2:58 pm     Reply with quote
Hi guys
is there any other way of doing this program.
#include <12F629.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES BANDGAP_HIGH
#define PWM_PIN       Pin_A2
#define Rx_Input      Pin_A3
#define Min_Width     0x07      // 1.0mS / 128uS = 07dec = 07h.
#define Max_Width     0x0F      // 2.0mS / 128uS = 16dec = 0Fh.
#define Low_Trip      0x0A      // 1.4mS / 128uS = 10dec = 0Ah.
#define High_Trip     0x0C      // 1.6mS / 128uS = 12dec = 0Ch.
#define Max_Frame     0x9C      //  20mS / 128us = 156dec = 9Ch.
int i;
void lighton(){
for(i=0; i<30; i++){
output_high(PWM_PIN);
delay_us(5500);
output_low(PWM_PIN);
delay_us(4500);
void wait_for_low_to_high() {
   while(input(Rx_Input)) ;
   delay_us(3);
   while(!input(Rx_Input));
void wait_for_low() {
   delay_us(3);
   while(input(Rx_Input));
   int PulseWidth;
   int BeginPulse;
   setup_counters( RTCC_INTERNAL, RTCC_DIV_128 );
    wait_for_low_to_high();
    BeginPulse = get_rtcc();
    wait_for_low();
    PulseWidth = (get_rtcc() - BeginPulse);
    if (PulseWidth >= High_Trip)
         lighton();
thanks
Pete
PostPosted: Sun Jul 13, 2008 3:47 pm     Reply with quote
Yes.
But for us to give a hint to a solution it would be very helpful if you can tell us why your implementation isn't good for the job.
pdl
PostPosted: Mon Jul 14, 2008 12:42 am     Reply with quote
I am trying to light an led with out a resistor and with out it flickering and turning ever now and again
Pete
PostPosted: Mon Jul 14, 2008 1:28 am     Reply with quote
I could give you ten possible suggestions for implementing such a function and than have you choose the single suggestion fitting your needs ...
... or you give more details about your system and requirements.
Because of my limited (spare) time you'll have to do with the last option. Also explain _why_ your example code is not sufficient.
pdl
PostPosted: Mon Jul 14, 2008 2:01 am     Reply with quote
Thank you for you help ckielstra as you can see by my code i am new to C.
The Led Flickers ever now and again
What i would like when the program sees 1.6ms and a bove the Led stays on until the pluse is no longer 1.6ms or greater.
its just not stable a the minute
Pete
PostPosted: Mon Jul 14, 2008 3:27 am     Reply with quote
I don't know the characteristics of your input signal, but most likely the waiting for a pulse is what causes your LED to flicker.
The easiest method to solve this is by removing the LED modulation out of the main loop. Create a timer driver interrupt which will drive your LED. Right now I don't have time to post example code but if you search this forum with the keywords 'soft PWM' you will find some related posts.
pdl
PostPosted: Mon Jul 14, 2008 3:43 am     Reply with quote
I have tried that
I tried to use some of this code but could not get it to work properly.
The input pulse is a 1ms to 2ms pulse the same type of pluse that drives a model servo.
thanks
Pete
#include <16F877.H>
#use delay(clock = 4000000)
#define PWM_PIN PIN_B0
#define LOOPCNT 39
int8 width;
#INT_RTCC
void tick_interrupt(void);
main()
width = 0;
setup_counters(RTCC_INTERNAL, RTCC_DIV_1);
enable_interrupts(INT_RTCC);
// Step through all values for width, from 0 to 39.
// This will slowly increase the duty cycle from 0 to 100%,
// by doing one step every 100 ms.
for(width = 0; width <= LOOPCNT; width++)
#INT_RTCC
static int8 loop = LOOPCNT;
static int8 pulse;
if(--loop == 0)
loop = LOOPCNT;
pulse = width;
if(pulse)
pulse--;
PostPosted: Mon Jul 14, 2008 5:12 am     Reply with quote
#include <16F877.H>
Are you sure this is correct? Your first post was using a PIC12F629
The XT fuse is for an external crystal. Your first post was using the internal clock generator.
pdl
PostPosted: Mon Jul 14, 2008 5:19 am     Reply with quote
Yes i changed the pic i was using
i tried to use some of this code with the pulse measurement code and i could not get it working
Pete
PostPosted: Mon Jul 14, 2008 6:36 am     Reply with quote
Try to be more detailed in your descriptions, just saying 'it's not working' is too limited. What do you expect to see, what is different and what behaviour do you actually see?
Are you using the PIC16F877 or the PIC16F877A? The first is very old...
Note that the PIC16F877 has two internal PWM hardware modules which are easier to use, will work more accurate and have less impact on the CPU usage than the soft PWM based on interrupts.
pdl
PostPosted: Mon Jul 14, 2008 7:44 am     Reply with quote
Hi ckielstra
I am using the 12f629
When i say it did not work i was putting a 1ms to 2 ms pulse in on PIN_A3 and was not getting anything out of PIN_A2 but looking at it now i think that the ICD was setup for MCLR and not I/O.
I expect For the LED to light when i put a 1.6ms pulse on PIN_A3
PIN_A2 should have a 100hz PWM output a 50% duty
When the input pulse is below 1.6ms the LED should stay turned off and not come on until the 1.6ms pulse is back on the input pin.
hope this a bit more clear
Pete
SherpaDoug
PostPosted: Mon Jul 14, 2008 9:18 am     Reply with quote
Pete
So what sets the current during the ON time? Are you relying on the over-current protection of the PIC pin logic? That is going to be very temperature sensitive. This may be OK for a home project, but I would not recommend it for a commercial product!
pdl
PostPosted: Mon Jul 14, 2008 9:47 am     Reply with quote
I am using a Mosfet as the LEDs i am using draw 350ma at 3.6v
Pete
PostPosted: Mon Jul 14, 2008 3:52 pm     Reply with quote
Thanks for explaining your circuit in more detail. Now it makes more sense.
Does it work after fixing the MCLR setup?
If not, please post your code for the PIC12F629 and tell us what behaviour you see.
pdl
PostPosted: Mon Jul 14, 2008 6:42 pm     Reply with quote
Here is my code so far i now can turn on some sort of PWM with my input which is 1ms to 2ms and the trip should be 1.6ms but i can not get the
timing right to get 100Hz 50% duty from the PWM pin
I have a Mosfet which i supply 7.4v to and with the 50%duty from the PWM i was hoping to get 3.7v output from the Mosfet.
thanks
Pete
#include <12F629.h>
#FUSES NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, NOBROWNOUT, BANDGAP_HIGH
#define PWM_PIN           PIN_A2
#define Rx_Input          PIN_A3
#define LOOPCNT 39
int8 width;
#INT_RTCC
static int8 pulse;
if(--loop == 0)
   loop = LOOPCNT;
   pulse = width;
if(pulse)
   pulse--;
   delay_us(3);
   delay_us(3);
   int PulseWidth;
   int BeginPulse;
width =19;
         wait_for_low();
      if (PulseWidth <= Low_Trip)
         clear_interrupt(INT_RTCC);
         disable_interrupts(INT_RTCC);
         disable_interrupts(GLOBAL);
                  output_low(PIN_A2);
Goto page 1, 2  Next
Page 1 of 2
