pattousai
help to understand what is going on in #int_rda code |
Posted: Thu Jul 10, 2008 8:03 pm |
hi everybody!
First, i will tell what i want to do.
I have a modem connected to a PIC and the receiving sms are routed directly to the terminal, so, when the modem receive a sms, it will send to the pic something like:
+CMT: "08488471617",,"08/07/10,14:43:31-140"
config1=0 config2=20 config3=5,5
what i want to do is extract the numbers.
ok, but i wrote a simple code to just get the string received and print them to a 'debug stream'. the code is:
#include <16f628a.h>
#fuses HS, NOMCLR, NOWDT, NOLVP
#use delay(clock=17287200)
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, stream=GSM) //hardware usart
#use rs232(baud=9600, xmit=PIN_B3, rcv=PIN_B0, stream=PC)
char msg[80];
char c;
int1 flag1 = true;
#int_rda
void interrupcao_serial()
output_high(PIN_A2);
fgets(msg, GSM);
fprintf(PC, "%s", msg)
output_low(PIN_A2);
enable_interrupts(INT_RDA);
fprintf(PC, "Starting the program\r\n");
fprintf(GSM, "AT+CNMI=3,2\r\n");
delay_ms(3000);
while(1){
if( input(PIN_B4) && flag1 ){
fprintf( GSM, "AT\r\n" );
delay_ms(3000);
flag1 = false;
if( !input(PIN_B4) && !flag1 ){
flag1 = true;
well, once this code enter in the #int_rda, the led in PIN_A2 just don't go off, i.e., the program don't leave the interrupt and just can't do anything else (obviously), but the message is sent to the PC. I tried to turn on another LED between the fprintf and the output_low(PIN_A2), and the led turned on, but the PIN_A2 justn't go off and i really don't understand why
i tried the get_string instead gets and result in the same way. also tried to put "\r\n" (just "\r", just "\n") in the fprintf(PC...) but with no changes
well, that's it... i would like some help to understand what is going on
also... if anyone want to suggest a way to do what i want (described in the begging of the post) i would really appreciate (i wonder how is the best way to catch exactly the numbers)
ops, i almost forgot, i'm using the 4.057 compiler
thanks everybody. |
Posted: Fri Jul 11, 2008 3:00 am |
Do a search here about interrupts.
General comment, _unless you know -exactly- what the implications are, always ensure that interrupts can be handled in the time 'between' events_.
In your case, there are two big problems. The interrupt triggering, implies there is just _one_ character waiting to receive. You then go and call 'gets', which will sit wait, for an entire _string_ to arrive. Having done this, you then call a print, which will take as long to send the string, as it took to arrive, and for the entire time, any characters arriving _will_be missed.
This sort of handling error, is probably the commonest single posting cause here!.
Now, as a 'example', I'll post a basic interrupt based 'fetch string' approach, which hopefully will get you going.
#device *=16
#define MESSAGE_LENGTH (80)
int buffer_in_use=0;
char message[2][MESSAGE_LENGTH];
int1 message_available=false;
#int_rda
void serial_gets_isr(void) {
char temp_chr;
static int input_locn=0;
temp_chr=fgetc(GSM); //receive the _one_ character
message[buffer_in_use][input_locn++]=temp_chr; //add it to the buffer
if (input_locn>(MESSAGE_LENGTH-1)) input_locn=MESSAGE_LENGTH-1;
//If more than 'buffer' characters arrive, the data will be clipped at the
//size of the buffer.
if (temp_chr=='\n' || temp_chr=='\r' || temp_chr=='\0') {
message_available=true;
message[buffer_in_use][input_locn]='\0'; //null terminate the string
buffer_in_use^=1;
input_locn=0;
output_low(PIN_A2);
int8 key_ctr=0;
int8 buffer_not_in_use;
//No delays needed
while(1){
if( input(PIN_B4) ) {
if (++key_ctr >= 4) {
//ensure key is pressed for four loops
else {
key_ctr=0;
if (message_received) {
//Now, the whole message, is sitting in the buffer 'not' in use
message_received=false; //must clear this ASAP
buffer_not_in_use=buffer_in_use^1; //select the buffer
printf(PC,"%s",&message[buffer_not_in_use][0]);
//print the received message
//Though this may take absolutely 'ages', any arriving characters
//will be stored in the 'other' buffer, while this happens.
//This will only go 'wrong', if two messages arrive in the time it
//takes to printout the first.
//Consider increasing the baud rate on the software RS232 to the
/PC, to minimise this problem...
This is 'untried' code (just typed it here), but should be pretty close to right. Basically, I have allocated two receive buffers. The interrupt toggles your 'A2' line for every character received, and then sets a 'message received' flag, when it sees a terminating character (line feed, carriage return, or a binary '0'). It immediately starts writing new characters to the _other_ buffer. Your 'main', gets rid of all delays, and sits looping quickly, testing the input bit, and checking the 'received' flag. When a message is received, it prints it out (from the first buffer). To debounce the input, without delays, I require the line to go 'high' for 4 loops.
Hope you get the idea.
pattousai
Posted: Fri Jul 11, 2008 1:03 pm |
thanks for the help, i will try this aprox right away.
Well, the print to the PC it's just a test, what i will do is take this incoming string (something like: config1=10 config2=20 config3=30) and extract the numbers (10, 20, 30).
I'm thinking in using tokens to get just config1=10, config2=20 and config3=30, and then check the first 'n' characters. if then are really configx= i will get the other part of the string and put them into a local variable.
So... you think this will take much longer? it seems to me that yes...
thanks again |
Posted: Fri Jul 11, 2008 1:36 pm |
The 'print', takes basically just on 1mSec/character. If you have a 60 character string, about 60mSec. Copying a number out of the incoming buffer, takes only perhaps a uSec. You can perform something like 4 floating point divisions (normally considered to be a really 'slow' operation), in the time needed to print just one character!....
Serial is _slow_.
pattousai
Posted: Fri Jul 11, 2008 1:49 pm |
ok, thanks very much, this really help to put somethings in 'perspective' |
