ICD and code protection bit problem
hayee
PostPosted: Wed Jul 09, 2008 11:06 pm     Reply with quote
Hi Everyone;
i am using pic16f870 and ccs c compiler (version 4.020).
when i enable ICD=true and set "protect" in fuses like(#fuses PROTECT,NOLVP,WDT) and program it through ICD, it program the IC but the IC is not code protected
But when i disable ICD=true and set "protect" in fuses like(#fuses PROTECT,NOLVP,WDT) and program the IC with programmer then the IC is code protected.
i wanna know that where is the problem occurs.
Thanks.
Indy
PostPosted: Thu Jul 10, 2008 2:22 am     Reply with quote
You can use the ICD as a debugger or as a programmer. You only have to set ICD=TRUE when using the ICD as a debugger.
A debugger does not work when the PROTECT fuse is set, that's why the fuse is disabled by the compiler.
hayee
PostPosted: Thu Jul 10, 2008 3:46 am     Reply with quote
i am using ICD as a programmer not as a debuger.so why this error is happening.
treitmey
PostPosted: Thu Jul 10, 2008 8:29 am     Reply with quote
Since you are using the ICD as a programmer, do you have the
ICD=True in the code, or do you have it commented out?
hayee
PostPosted: Fri Jul 11, 2008 12:52 am     Reply with quote
my configuration is like that
#include <16f628A.h>
#device ICD=TRUE
#device *=16
#fuses HS, WDT, NOLVP, NOBROWNOUT, PROTECT, PUT
#use delay(clock=20M)
i have enable ICD and also PROTECT in fuse.
treitmey
PostPosted: Fri Jul 11, 2008 8:03 am     Reply with quote
My guess is that when you have
ICD=TRUE then the compilers thinks
In Circuit Debugger = TRUE; eg: your using the debugger.
Then it says.. Ohh he is using the debugger, so I can't set the protect fuse.
When you comment out the ICD=TRUE then everything works.
NICE
PostPosted: Thu Jan 21, 2010 12:02 pm     Reply with quote
And it was just so nice of the compiler to let me know that it didn't protect anything for me.
