PIC hangs when enabling global interrupts
fredgilman
PostPosted: Thu Jul 10, 2008 9:27 pm     Reply with quote
Hi all,
I'm in the processing of learning CCS C on a PIC16F688 and just started to play around with interrupts. I started out with a simple test, but for some reason the pic hangs when processing the enable_interrupts(GLOBAL) command. I've determined this by making an led flash after each command, and it always stops when it gets to that line. Here's a somewhat barebones test I tried:
#include <16F688.h>
#FUSES NOWDT, INTRC_IO, NOPROTECT, NOMCLR
#define led  PIN_C2
int changed=0;
#int_RA
void  RA_isr()
   changed=1;
   clear_interrupt(int_RA);  //Added incase the interrupt was constantly enabled
   enable_interrupts(INT_RA);
   output_high(led);   //flash an LED once the interrupts are enabled
   output_low(led);
   while (1){
      if (changed){    //The interrupt's been triggered!
         output_high(led);
         delay_ms(300);
         output_low(led);
Any suggestions on what I'm doing wrong?
Thanks.
PostPosted: Thu Jul 10, 2008 10:55 pm     Reply with quote
Read the 16F688 data sheet. It tells you what to do.
4.2.3 INTERRUPT-ON-CHANGE
The user, in the Interrupt Service Routine, clears
the interrupt by:
a) Any read or write of PORTA. This will end the
mismatch condition, then
b) Clear the flag bit RAIF.
A mismatch condition will continue to set flag bit RAIF.
Reading PORTA will end the mismatch condition and
allow flag bit RAIF to be cleared.
Note that the compiler inserts code to do item (b).
You don't have to do it.
fredgilman
PostPosted: Fri Jul 11, 2008 12:12 pm     Reply with quote
Ah ha! Reading the pin in the interrupt function worked! I had read the datasheet before, but it never occurred to me that item (a) was the culprit, as the problem seemed to be with another command. Thanks!
