Lock up during EEprom write
nmeyer
PostPosted: Thu Jul 10, 2008 11:08 am     Reply with quote
I am developing a program that will load the eeprom of the chip on the first power up after the program has been loaded. I am using a PIC18F8722 and the internal_eeprom.c program in the ccs folders to accomplish this. This was working fine until i reach a location in the eeprom over ~200. Since the eeprom is 1024 bytes, i should have 1024 locations to write to, so i am not sure what the issue is. If i have the program loading up the first 200+ locations it just hangs up during the write process. My program is way to large to post here, but i was hoping someone else might have used the internal_eeprom.c and might have some clues. I did change the INT_EEPROM_ADDRESS to a int 16 from an INT8. Could i be trying to write too much to the eeprom at one time or do i need delays between the writes?
Compiler V4.062
Sample
pacres_A=0;
   write_float_eeprom(181,pacres_A);
   pacres_B=0;
   write_float_eeprom(185,pacres_B);
   pacres_C=0;
   write_float_eeprom(189,pacres_C);
   pacres_D=0;
   write_float_eeprom(193,pacres_D);
   pacres_E=0;
   write_float_eeprom(197,pacres_E);
   pacres_F=0;
   write_float_eeprom(201,pacres_F);
PostPosted: Thu Jul 10, 2008 11:40 am     Reply with quote
What happens if you strip your program down so that it contains only
this code ? Does it still fail ? If so, post the program.
pacres_F=0;
