jinggy
looping problem |
Posted: Thu Jul 10, 2008 8:01 am |
hello all. my code is shown below. the problem is the for(addr=0; addr < EEPROM_SIZE; addr ++) is not working. everytime the data is save into addr = 0.
ur help will be much appreciated!
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
char k;
int16 addr;
int8 datain[1];
int8 dataout[1];
byte string1[] = "0F02A670DF";
byte string2[] = "0F02A66F79";
typedef enum { INITIAL_STATE, KB_PROCESSING_STATE, SCAN_TAG_STATE } state_t;
state_t state = INITIAL_STATE;
int i;
byte buf[12];
lcd_init();
kbd_init();
ds1307_init();
init_ext_eeprom();
usb_init(); //inicializamos el USB
for(addr = 0; addr < EEPROM_SIZE; addr++)
switch ( state )
case INITIAL_STATE:
lcd_putc("\fIICP\n");
delay_ms(2000);
lcd_putc("\fEnter Subject Code:\n#:cont *:delete");
state = KB_PROCESSING_STATE;
case KB_PROCESSING_STATE:
switch ( kbd_getc() )
case 0:
case '*':
lcd_putc ( '\f' );
case 'A':
lcd_putc ( "\fUSB" );
USB_TRANSFER();
case '#':
lcd_putc ( "\fEntered\n" );
delay_ms(2000);
lcd_putc("\fScan Tag:\n");
state = SCAN_TAG_STATE;
default:
lcd_putc(k);
KEYPAD_WRITE_EEPROM();
write_ext_eeprom(addr, input);
case SCAN_TAG_STATE:
output_low(PIN_C6);
while (getc() != 0x0A) ; //wait for the tag
//Now only have 11 characters to read
for ( i = 0; i < 11; ++i )
buf[i] = getc();
if( strncmp(buf,string1,10) == 0)
lcd_putc("\f1");
input = 0x01;
ds1307_get_date(day,month,yr,dow);
ds1307_get_time(hrs,min,sec);
write_ext_eeprom(addr,sec);
write_ext_eeprom(addr,min);
write_ext_eeprom(addr,hrs);
write_ext_eeprom(addr,day);
write_ext_eeprom(addr,month);
write_ext_eeprom(addr,yr);
else if( strncmp(buf,string2,10) == 0)
lcd_putc("\f2");
input = 0x02;
lcd_putc("\fUnauthorized tag");
delay_ms(5000);
output_high(PIN_C6);
treitmey
Posted: Thu Jul 10, 2008 8:35 am |
Just a quick look, but it seems that addr isn't incremented after the
write_ext_eeprom.
so you write sec to address 0 then min to address 0 then hrs to address 0
everything is written to the same spot. |
jinggy
Posted: Thu Jul 10, 2008 10:32 am |
i do realize that but how do i change the code? and why cant addr++ make the value of addr increase everytime after a data is being saved? |
Indy
Posted: Thu Jul 10, 2008 11:11 am |
jinggy wrote: | i do realize that but how do i change the code? and why cant addr++ make the value of addr increase everytime after a data is being saved? | addr++ will increment the address but look at the following code: Code: | write_ext_eeprom(addr,sec);
write_ext_eeprom(addr,yr); | Here you are using the same value of addr 7 times. One solution is to replace all these references by 'addr++'.
Don't forget to add an extra test for overflowing the maximum eeprom address. The for-next loop does contain a test for EEPROM_SIZE but now you are writing 7 bytes at once.
Problem 2: the first time you enter the loop. Because you have the state INITIAL_STATE running first the value of addr has increased to 1 when you are using it the first time. Now your data starts at address 1 instead of 0.
This can be solved by removing the for-loop. Only increment addr when you call write_ext_eeprom as suggested above.
Problem 3: Addr is never reset to 0. |
jinggy
Posted: Thu Jul 10, 2008 12:46 pm |
thanks for ur reply Indy!
so meaning that i have to remove the For loop and change addr to addr++ right?
can i change the code to:
if (addr < EEPROM_SIZE)
write_ext_eeprom(addr++, input)
write_ext_eeprom(addr++, sec)
write_ext_eeprom(addr++, yr)
and when i read back the data, i do the same? |
Indy
Posted: Thu Jul 10, 2008 5:41 pm |
jinggy wrote: | can i change the code to:
and when i read back the data, i do the same? | Yes, that's the basic idea. Don't forget to change 'addr' to 'addr++' in all other calls to write_ext_eeprom().
Code: | if (addr < EEPROM_SIZE) | Change this to: Code: | if ( (EEPROM_SIZE - addr) >= 3 ) | '3' because you are going to write 3 bytes and we want to check if enough space is available. |
jinggy
Posted: Thu Jul 10, 2008 8:31 pm |
so i've changed the code to as below and it's not working. any idea?
writing:
int i;
byte buf[12];
lcd_init();
kbd_init();
ds1307_init();
init_ext_eeprom();
switch ( state )
case INITIAL_STATE:
delay_ms(2000);
case 0:
case '*':
lcd_putc ( '\f' );
case 'A':
USB_TRANSFER();
case '#':
delay_ms(2000);
default:
lcd_putc(k);
if ( (EEPROM_SIZE - addr) >= 1 )
write_ext_eeprom(addr++, input);
output_low(PIN_C6);
buf[i] = getc();
lcd_putc("\f1");
input = 0x01;
if ( (EEPROM_SIZE - addr) >= 6 )
write_ext_eeprom(addr++,sec);
write_ext_eeprom(addr++,min);
write_ext_eeprom(addr++,hrs);
write_ext_eeprom(addr++,day);
write_ext_eeprom(addr++,month);
write_ext_eeprom(addr++,yr);
delay_ms(5000);
reading:
void USB_TRANSFER()
usb_task(); //habilita periferico usb e interrupciones
usb_wait_for_enumeration();
if(usb_enumerated()) //si el PicUSB está configurado
if (usb_kbhit(1)) //si el endpoint de salida contiene datos del host
usb_get_packet(1, datain, 1); //cojemos el paquete de tamaño 3bytes del EP1 y almacenamos en recibe
switch(datain [0]) //command
case 0x01:
dataout = read_ext_eeprom(addr++);
usb_put_packet(1, dataout, 1, USB_DTS_TOGGLE);
![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Fri Jul 11, 2008 3:21 am |
Try initialising addr.
So, where you declare it:
int16 addr=0;
or just add the line 'addr=0' before you use it.
Unless you declare a variable as 'static', it is _not_ by default cleared.
