disable undesired outputs on P1A, P1B, P1C and P1D
pokiko
PostPosted: Wed Jul 09, 2008 1:32 pm     Reply with quote
hi
i am using pic18f4520 with 16Mhz osc. i have an input from the TOCKI pin that i use for ccp. Also keypad is connected to portD.
when i push on some of the buttons on keypad, some undesired inputs appear on the LCD. port_d pins of d5,d6,d7 causes this situation, these three pins must configured as input.
I guess P1A,P1B,P1C and P1D cause this situation ,which are for ECCP, all have to be shutdown, . so how can i disable them. i want to use ccp module in compare mode but i dont want to use eccp module.
thanks.
          setup_oscillator(OSC_16MHZ);
            SETUP_TIMER_0( RTCC_EXT_L_TO_H | RTCC_DIV_1);
            setup_timer_1(T1_DISABLED);
            setup_timer_2(T2_DIV_BY_16,250,15);
            output_low( PIN_E0 );
            setup_CCP1( CCP_COMPARE_INT );
            setup_CCP2( CCP_COMPARE_INT );
            disable_interrupts( GLOBAL );
            enable_interrupts(INT_CCP1);
            enable_interrupts(INT_CCP2);
            setup_psp(PSP_DISABLED);
            setup_spi(SPI_SS_DISABLED);
            SETUP_ADC(ADC_CLOCK_DIV_32);
            setup_adc_ports(AN0_TO_AN3);
            set_timer0(65535);    // Arm external trigger
            CCP_1=maxPERYOD;
            CCP_2=CCP_1 + 5000;  // Second pulse 1ms after pulse 1
            set_timer1(0);
PostPosted: Wed Jul 09, 2008 2:18 pm     Reply with quote
Post your compiler version.
pokiko
PostPosted: Wed Jul 09, 2008 3:45 pm     Reply with quote
My compiler version is 4.049.
I have got the solution. It was about the connections of portD. they are also connected to LCD. I added a delay_us then it worked.
thanks PCM programmer.
