Pic16F690 problem
freddan007
Pic16F690 problem
PostPosted: Mon Jul 07, 2008 4:43 am     Reply with quote
Hello!
I have a pickit2 starterkit and a ccs c compiler.
And it works great but I am having trouble with the input.
I use this code but when I press the button on my experimentcard nothing happens.
#include <16F690.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT , PUT
   if((input(PIN_A3)))
     output_high(PIN_C0);
PostPosted: Mon Jul 07, 2008 7:12 am     Reply with quote
How have you wired the button?.
Normally, you will need a button pulling the signal either down to ground, or up to 5v, and a _resistor_ pulling the same line the 'other way' (so button 'down' to 0v, and resistor 'up' to 5v, or the whole combination 'reversed'). Now the 690, has 'programmable' pull up resistors on PORTA, but these have to be turned on by _you_. Look at the port_a_pullups instruction. Without the resistor, there is nothing to make the line go high...
Note also, that if you are using the internal pullups, and the button to ground, the logic you show is reversed. The signal will go 'true', when the button is _not_ pushed.
freddan007
PostPosted: Mon Jul 07, 2008 8:41 am     Reply with quote
All the asm examples work correctly
PostPosted: Mon Jul 07, 2008 10:17 am     Reply with quote
In which case, they are doing something different. Accessing a different pin, or making different assumptions.
They are probably setting the pullup resistors, which is why I suggest this.
The problem is that we don't know how the board you have is wired (hence my first comment).
With the right wiring, what you have posted will (sort of) work. However it'll only work once (since as soon as the pin is seen high, the output will set, and never release), and it requires a pin that goes high for 'active', which is the opposite of most normal wiring.
PostPosted: Mon Jul 07, 2008 10:33 am     Reply with quote
Look at page 41 in the PicKit2 "low pin count" user manual:
http://ww1.microchip.com/downloads/en/DeviceDoc/Low%20Pin%20Count%20User%20Guide%2051556a.pdf
Probably it will work if jumper JP5 is installed and you add the NOMCLR
fuse.
PostPosted: Mon Jul 07, 2008 11:23 am     Reply with quote
how do i install the jp5 jumper?
PostPosted: Mon Jul 07, 2008 11:44 am     Reply with quote
This board is a Microchip product and you should ask questions about
it on their forum. They have a FAQ on the PicKit2 board. FAQ
question "F" is about the pushbutton pin:
http://forum.microchip.com/tm.aspx?m=270347
Here is the Microchip forum for questions on how to use the PicKit2
"low pin count" board:
http://forum.microchip.com/tt.aspx?forumid=15
