Cannot output low
John5788
Cannot output low
PostPosted: Thu Jul 03, 2008 3:41 pm     Reply with quote
hello, i am trying to learn how to develop on the pic 18f4550 and am running into, a probably trivial problem.
here is my code
#include "18F4550.h"
int main(void)
   output_low(PIN_A1);
   return 0;
All i want it to do is output a low on pin A1, but when i check the voltage with a multimeter, it is 4.867 volts. what am i doing wrong?
PostPosted: Thu Jul 03, 2008 3:50 pm     Reply with quote
Just a few hours ago somebody asked almost the same question. The other question was for an input but most likely the same cause: http://www.ccsinfo.com/forum/viewtopic.php?t=35297
John5788
PostPosted: Thu Jul 03, 2008 3:59 pm     Reply with quote
i changed the code a bit to this:
int main(void)
   setup_adc(ADC_OFF);
   setup_adc_ports( NO_ANALOGS );
      output_low(PIN_A1);
   return 0;
and it is still outputting 5v.
more information: i am using the picdem fsusb demo board right now.
PostPosted: Thu Jul 03, 2008 4:13 pm     Reply with quote
My mistake, the outputs on this chip are not affected by the analog port settings (only the inputs are affected).
Your program is so simple that it can only fail when something very basic is wrong. Did you post all program code? Now the processor include and fuses are missing.
PostPosted: Thu Jul 03, 2008 4:17 pm     Reply with quote
I am using the picdem fsusb demo board right now.
This board comes with a built-in USB bootloader that uses pin A1
to detect if a USB cable is plugged into the board. See page 11
(page 15 in the Acrobat reader) and also the schematic:
http://ww1.microchip.com/downloads/en/DeviceDoc/51526b.pdf
John5788
PostPosted: Thu Jul 03, 2008 5:13 pm     Reply with quote
ok so i took a glance at the datasheet some more and it says RD0 is connected to the D1 LED, so i modified my code:
int main(void)
      output_high(PIN_D0);
   return 0;
now the LED lights up, its working!
so as I understand, I cannot use RA0, RA1, RB0, RB1, RB2 for anything interesting, but all other lines are fair for use?
PostPosted: Fri Jul 04, 2008 2:24 am     Reply with quote
You can use A0, A1, B0, B1, B2 as normal, _but_ you need to turn off the devices attached to them.
Quite a few things involved:
1) Fuses - NOPBADEN - otherwise PORTB, wakes up set to use for the ADC
2) setup_adc(NO_ANALOGS) (you already have this one).
3) setup_comparator(NC_NC_NC_NC) - otherwise the comparator uses various pins.
