RANTT44 Guest
What is wrong with this robot code ? |
Posted: Mon Jun 30, 2008 10:59 am |
HI
I HAVE BUILT A BIG ROBOT WHICE WORK FINE MECHANICLY BUT THE SOFTWARE IS NOT GOOD AT ALL.
THE ROBOT SHOULD START GOING STRAIGHT AND BLINK A LED, AND IF HE GETS A HIGH VOLTAGE AT A2 HE GO BACK LITTLE AND THEN TURN TO A RANDOM SIDE,THEN CONTINUE GO FORWARD
MY INTERRUPT IS REALLY STRANGE....ITS DONE EVEN IF NOT ON HIGH....
I ADD MY CODE AND SORRY FOR MY ENGLISH.
THANX.
Code: | #include <16F690.h>
#fuses XT,NOWDT,NOPROTECT,put
#use delay(clock=8000000)
#include <stdlib.h>
#define RAND_MAX 2
#int_ext
int y;
void button_isr() {
delay_ms (40); //debounce
if( input(PIN_A2)==1 )
output_low(PIN_C2); //stop engines
output_low(PIN_C3);
output_low(PIN_C4);
output_high(PIN_C3);
delay_ms(50);
output_high(PIN_C3); // go back 20 cm
output_low(PIN_C2);
output_high(PIN_C4);
output_low(PIN_C5);
y=rand(); // y gets a random number to decide where to turn
if(y==0)
{ output_high(PIN_C3); //turn RIGHT
output_low(PIN_C2);
output_high(PIN_C5);
output_low(PIN_C4);
delay_ms(500) ;
{ output_high(PIN_C2); //turn LEFT
output_low(PIN_C3);
output_low(PIN_C5);
delay_ms(500) ;
enable_interrupts(global);
enable_interrupts(int_ext);
ext_int_edge( H_TO_L );
output_high(pin_b6); //TURN ON THE LED FOR A WHILE
delay_ms(5000);
output_low(pin_b6);
output_high(PIN_C2); //go straight
output_low(PIN_C3);
output_low(PIN_C4);
output_high(pin_b6); //BLINK A LED
delay_ms(300);
output_low(pin_b6);
delay_ms(300);
Posted: Mon Jun 30, 2008 11:30 am |
Quote: | #int_ext
int y;
void button_isr() { |
Don't put any lines of code between the #int_ext and the function
declaration.
Do it like this:
Code: | #int_ext
THATS ALL ??? |
Posted: Mon Jun 30, 2008 12:31 pm |
what about my interrupt?
i am sure its not ok...
can you see something wrong ? |
Posted: Mon Jun 30, 2008 12:47 pm |
Your interrupt routine was not even put into the HEX output file,
because you put the "int y;" variable in between the #int_ext
and the interrupt function.
Fix the problem that I stated in my post and then try it again. |
Posted: Mon Jun 30, 2008 1:59 pm |
Also, you should change the edge used, then clear the interrupt, and only enable it after this. If you read the chip's data sheet, you will see that changing the selection for the 'edge', can result in the interrupt being trigered.
Posted: Mon Jun 30, 2008 4:29 pm |
Besides all the above: Code: | #fuses XT,NOWDT,NOPROTECT,put
#use delay(clock=8000000) | The XT fuse only supports crystals up to 4MHz. For your 8MHz crystal set the HS fuse instead.
Code: | output_low(PIN_C2); //stop engines
output_low(PIN_C3);
output_low(PIN_C4);
output_high(PIN_C3); | This looks wrong to me:
- you set PIN_C3 two times
- you don't set PIN_C5.
- Assuming you are driving a standard H-bridge the output_high in the last line should be an output_low instead.
The start of your main is missing code for disabling the analog ports, comparators and weak pull-up resistors. Many of these internal devices have priority over the use of the pin as an I/O pin. So when you think the port is an output port it might actually be configured as analog input. Check the shared functions of each I/O pin you are using against the datasheet.
An easy method to get all required setup-functions is by using the CCS project wizard to create a new project. Copy all generated start-up code to your program. |
wow...thanx a lot ! one more.. |
Posted: Tue Jul 01, 2008 1:12 am |
I have learn so many things from your answers..
Thanx a lot !
Also one more question, why i cant debug my program without this ICE thing? I just want to enter F8 and see the debugger line go over my code line by line, as i could do in visual basic.
When i try debugger he says things about ice and etc.
I just want a simple debugging to go over my code. |
Posted: Tue Jul 01, 2008 2:32 am |
MPLAB, contains a simulator, which should do what you want.
If you think about it, in VB, you are writing the code 'on' a processor, that can run it. Hence this processor can be used to debug. With the PIC, the processor is a completely different device. Hence you need either a software 'simulation' of this processor (which is what MPLAB contains), or an external processor, which can send debugging information to the PC (ICE, or ICD).
THANX A LOT ! |
Posted: Wed Jul 02, 2008 11:32 am |
THANX !
THE MPLAB IS ASEMBLER CAN I LOAD 'C' ? |
