Comparator interrupt coming all the time
salamander
PostPosted: Fri Jun 27, 2008 1:30 am     Reply with quote
if got this problem with comparator interrupt for some time now ;)
Pin B1 is toggled with 4/5 the time low and 1/5 high, but Pin B3 is always low and there is now reason for the COMP interrupt to come as A4 is high all the time....
I'm using the 18F2550
#include "C:\Programme\PICC\Examples\m.h"
#byte COCON = 0xfb4
#byte PIR2 = 0xfa1
#int_COMP
void COMP_isr(void) {
   int cur;
   output_high(PIN_B1);
   cur = COCON;
   output_low(PIN_B1);
   setup_comparator(A0_A3_NC_NC_OUT_ON_A4);
   enable_interrupts(INT_COMP);
   while (1) {
      output_high(PIN_B3);
      output_low(PIN_B3);
PostPosted: Fri Jun 27, 2008 2:28 am     Reply with quote
What are your fuses?.
A4, is multiplexed onto a couple of things. One is the USB RCV input, when using an external transceiver. This overrides it's operation as a comparator output pin (TRIS is ignored). It acts as an input, and won't then reflect the comparator behaviour.
I'd suggest stepping the code through in MPLAB, till you get to the main loop, and seeing what is in all the configuration registers. Though comparator inputs, are the 'default' on POR, sometimes, CCS fiddles with configurations on other parts of the chip, leading to problems.
I'd be most suspicious that A4, is not really reflecting the comparator output.
What compiler version?.
salamander22
PostPosted: Fri Jun 27, 2008 4:05 am     Reply with quote
thx for your hint and you are right with the A4 output, but the problem is the main_loop not running at all. And my comperator inputs are on static voltages now...
and I'm working with recent version:)
PostPosted: Fri Jun 27, 2008 4:33 am     Reply with quote
Add a small delay between the high and low outputs, in the main, and see if anything becomes visible. Your other set/reset, on B1, has an instruction between, which will take a few machine cycles, and could make the difference in terms of seeing the loop.
Give a version number. Somebody can test and see if it works for them, if we know the actual version, but 'recent', for CCS, could refer to several different versions....
The timings seem odd, since even if the interrupt was continuously triggered, I'd still expect the ratio between high and low, on B1, to be perhaps 30:1, not 5:1.
PostPosted: Fri Jun 27, 2008 8:46 am     Reply with quote
Thanks for your help, in the end it where multiple problems comming together: at first it needs some time to get out/into the isr whitch I did not think of and then I mixed up the input logic -> It could not work...
