rtcc interrupt problem
edbfmi1
PostPosted: Wed Jun 25, 2008 2:04 pm     Reply with quote
I am going to try and get this across without posting my code because it is rather lengthy.
I am using PCM 3.249
micro is a PIC16C71
using Picmaster Emulator
Problem I am having:
I am using the TMR0 timer and RB0 external interrupts for a "light dimmer" type design.
I have the GLOBAL interrupts disabled when I first go into the program while I do some initial house cleaning.
Also I have not enabled the TMR0 or RB0 interrupts.
After I am through with the "house cleaning"
I enable the RB0 interrupt and and then ENABLE GLOBAL interrupts.
Now for the problem.
While I am doing the "House Cleaning" the TMR0 rolls over and sets the TMR0 Interrupt Flag. (even though I did not enable it yet).
Now as soon as I ENABLE GLOBAL INTERRUPTS to look for the RB0 interrupt the program jumps to the TMR0 interrupt routine since the flag was set earlier.
Is there a way to clear the TMR0 interrupt flag before I do the GLOBAL INTERRUPT ENABLE?
PostPosted: Wed Jun 25, 2008 2:28 pm     Reply with quote
Download the CCS manual (June 2008 version):
Look at the list of CCS functions in the section on "Processor Controls"
on page 142. (Page 154 in the Acrobat Reader).
You will see the function that you need.
