filjoa
| keypad to lcd4x20 |
Posted: Tue Jun 24, 2008 8:50 am |
Hi
I try write on LCD 4x20 key how I press on my keypad
I make this program:
void main ()
int8 c;
int i;
lcd_init();
kbd_init();
i=0;
c = kbd_getc();
if(c=='*' && i==0)
lcd_gotoxy(0,3);
lcd_putc(" Insert: ");
i=1;
if(c=='#' && i==1)
lcd_putc('\f');
lcd_gotoxy(0,3);
lcd_putc(" OK");
i=0;
if(i==1 && c!='*')
lcd_gotoxy(8,3);
lcd_putc(c);
but now I have 2 problems:
1º- on LCD appear "insert:" and "OK" but dont appear key press.
2º- I need give one space before write like that" Insert:" and " OK" if I dont put space before 1º char appear in other line...
PS: when I put this program write on terminal all work fine.
this is file LCD4x20(I make some modifications on line positions):
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
//lcd_gotoxy(1,1); linha 1
//lcd_gotoxy(1,4); linha 2
//lcd_gotoxy(1,2); linha 3
//lcd_gotoxy(1,3); linha 4
if(Y==0)
address=0;
if(y==1)
address=0x40;
if(y==2)
address=0x14;
if(y==3)
address=0x54;
address+=x-1;
lcd_send_byte(0,0x80|address);
some one can help me?
regards |
filjoa
Posted: Tue Jun 24, 2008 2:05 pm |
The CCS lcd driver, and the also the Flex driver, do not use "0-based"
coordinates. The lowest coordinate value is 1.
For example, the 4 lines in a 20x4 LCD are numbered as: 1, 2, 3, 4.
You need to fix your code. Get rid of all the "0" coordinates. |
filjoa
Posted: Tue Jun 24, 2008 6:13 pm |
Hi, thanks PCM programmer
now this is solved but I have a new problem.
I like make some like that:
click on '*' and after press one number and click on '*' and program write on LCD the key how I have pressed.
void ast()
int8 c;
do
c = kbd_getc();
if(c!=0)
lcd_gotoxy(1,1);
lcd_putc(c);
}while(c!='*');
lcd_putc('\f');
void card()
void main ()
int8 c;
lcd_init();
kbd_init();
c = kbd_getc();
if(c!=0)
if((c=='*') || (c=='#'))
if(c=='*')
lcd_gotoxy(1,4);
lcd_putc(" key:");
ast();
if(c=='#')
lcd_gotoxy(1,4);
lcd_putc(" key:");
card();
with this program when I press '*' one time on LCD appear all white and when I press for 2nd time it clean LCD.
if some one can help me ...
best regards |
Wayne_
Posted: Wed Jun 25, 2008 2:14 am |
You are proberbly missing {}
do
c = kbd_getc();
if(c!=0) { // <------------
lcd_gotoxy(1,1);
lcd_putc(c);
}while(c!='*');
Indentation makes the code easier to read! |
filjoa
Posted: Wed Jun 25, 2008 10:12 am |
Hi
thanks, problem solved
now I try join 2 programs, idea is on LCD appear:
1ºline: IN: OUT:
2ºline: Voltage:
3ºline: GPS SPEED:
4ºline: keypad input:
keypad program:
| Quote: |
void card()
int8 c, ctemp;
do
c = kbd_getc();
if ((c=='0') || (c=='1') || (c=='2') || (c=='3') || (c=='4') || (c=='5') || (c=='6') || (c=='7') || (c=='8') || (c=='9'))
ctemp=c;
if(c!=0) {
lcd_gotoxy(6,4);
lcd_putc(ctemp);
}while(c!='#');
lcd_gotoxy(1,4);
if (ctemp=='1') lcd_putc("PC_ON ");
if (ctemp=='2') lcd_putc("INVERSOR ");
if (ctemp=='3') lcd_putc("DIAGNOSTICO ");
if (ctemp=='4') lcd_putc("LEDs INTERIORES ");
if (ctemp=='5') lcd_putc("LEDs EXTERIORES ");
if (ctemp=='6') lcd_putc("TV TUNER ");
if (ctemp=='7') lcd_putc("SONDA LAMBD ");
if (ctemp=='8') lcd_putc("opcao 8 ");
if (ctemp=='9') lcd_putc("opcao 9 ");
if (ctemp=='0') lcd_putc("PC_OFF ");
void ast()
int8 c, ctemp;
do
c = kbd_getc();
if(c!=0)
lcd_gotoxy(1,4);
if (c=='1') lcd_putc("PC_ON ");
if (c=='2') lcd_putc("INVERSOR ");
if (c=='3') lcd_putc("DIAGNOSTICO ");
if (c=='4') lcd_putc("LEDs INTERIORES ");
if (c=='5') lcd_putc("LEDs EXTERIORES ");
if (c=='6') lcd_putc("TV TUNER ");
if (c=='7') lcd_putc("SONDA LAMBD ");
if (c=='8') lcd_putc("opcao 8 ");
if (c=='9') lcd_putc("opcao 9 ");
if (c=='0') lcd_putc("PC_OFF ");
}while(c!='*');
lcd_gotoxy(1,4);
lcd_putc(" ");
void main ()
int8 c;
lcd_init();
kbd_init();
c = kbd_getc();
if(c!=0)
if(c=='*')
lcd_gotoxy(1,4);
lcd_putc("Insert key: ");
ast();
if(c=='#')
lcd_gotoxy(1,4);
lcd_putc("code: ");
card();
Temperature and voltage program:
| Quote: |
void ALARME()
output_high(SIRENE);
delay_ms(20000);
int i;
long TEMP_IN,TEMP_OUT;
float VOLT;
setup_adc_ports(AN0_AN1_AN3);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
output_low(LUZ_FUNDO);
output_low(SIRENE);
output_low(PC_SINAL);
output_low(TURNOFF);
lcd_init();
While(1)
TEMP_IN=0;
TEMP_OUT=0;
VOLT=0;
if (input(PC_SINAL)==1)
output_high(LUZ_FUNDO);
if (input(PC_SINAL)==0)
output_low(SIRENE);
/*****************Calculos das ADC's*********************/
set_adc_channel(0);
delay_us(10);
for(i=0; i<=100; ++i) TEMP_IN=TEMP_IN+Read_ADC();
TEMP_IN=(TEMP_IN/100);
set_adc_channel(1);
delay_us(10);
for(i=0; i<=100; ++i) TEMP_OUT=TEMP_OUT+Read_ADC();
TEMP_OUT=TEMP_OUT/100;
set_adc_channel(2);
delay_us(10);
for(i=0; i<=100; ++i) VOLT=VOLT+Read_ADC();
VOLT=VOLT/1000;
lcd_gotoxy(1,1);
lcd_putc("IN:");
lcd_gotoxy(10,1);
lcd_putc("OUT:");
lcd_gotoxy(3,1);
printf(lcd_putc("%2luC"),TEMP_IN);
lcd_gotoxy(14,1);
printf(lcd_putc("%2luC"),TEMP_OUT);
//printf(lcd_putc, ("\fIN:%2luC OUT:%2luC \r"),TEMP_IN,TEMP_OUT);
lcd_gotoxy(1,2);
printf(lcd_putc, ("Voltagem: %2.1gV \r"),VOLT);
lcd_gotoxy(1,3);
printf(lcd_putc, ("linha 3 "));
lcd_gotoxy(1,4);
printf(lcd_putc, ("linha 4 "));
/********************ALARME DE BAT FRACA*********************************/
if(VOLT==11.5)
delay_ms(5000);
if (VOLT==11.5) ALARME();
if (VOLT==11.0)
output_high(TURNOFF);
delay_ms(1500);
output_low(SIRENE);
in this program I have one problem, where I have
| Quote: |
lcd_gotoxy(1,1);
lcd_putc("IN:");
lcd_gotoxy(10,1);
lcd_putc("OUT:");
lcd_gotoxy(3,1);
lcd_gotoxy(14,1);
it dont appear value of TEMP_IN an TEMP_OUT, I need make this "printf(lcd_putc, ("\fIN:%2luC OUT:%2luC \r"),TEMP_IN,TEMP_OUT);" for see real values. why?
with this code appear on LCD "IN:%2luC OUT:%2luC"
after I try join this two program for when I press "*" or "#" run keypad part..
regards |
SET
Posted: Wed Jun 25, 2008 1:29 pm |
| Quote: | | Code: | printf(lcd_putc("%2luC"),TEMP_IN);
lcd_gotoxy(14,1);
printf(lcd_putc("%2luC"),TEMP_OUT); | |
Dont you mean -
| Code: | printf(lcd_putc, "%2luC", TEMP_IN);
lcd_gotoxy(14,1);
printf(lcd_putc, "%2luC", TEMP_OUT); |
filjoa
Posted: Wed Jun 25, 2008 3:11 pm |
| thanks for help SET this problem is solved... |
