Programming to control Servo Motor With PIC
kingseow
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Tue Jun 24, 2008 11:46 am     Reply with quote
I am looking for programming to control 5 servo motor with PIC16F877 and stand alone(Basically the program just need start all the servo when power on)...which only will rotate 70 to 120 degree then go back to where it start rotate for each servo motor and all the servo moving at same time.Below is the list of servo motor i using:
1)Three unit,
Hitec HS-55 Servo(rotate 100,110,120 degree)
2)One unit,
HS-6975HB servo(rotate 70 degree)
3)One unit,
HS-65HB servo(rotate 80 degree)
hope u all can help me,thk alot
kingseow
PostPosted: Wed Jun 25, 2008 2:58 am     Reply with quote
izzit possible i write like this ?
* Filename : pwm_servos.h
* I/O    : P1.4        -> A1  (PWM-CEX1)
*            P1.5        -> A2 (PWM-CEX2)
*            P1.6        -> A3 (PWM-CEX3)
*            P1.7        -> A4 (PWM-CEX4)
*            P1.8        -> A5 (PWM-CEX5)
/* Control the A1 servo */
void ServoL_back()
    CCAP1H = 243;
void ServoL_forward()
    CCAP1H = 230;
void ServoL_stop()
    CCAP1H = 0;
/* Control the A2 servo */
void ServoR_back()
    CCAP2H = 230;
void ServoR_forward()
    CCAP2H = 243;
void ServoR_stop()
    CCAP2H = 0;
/* Control the A3 servo */
void ServoL_back()
    CCAP3H = 243;
    CCAP3H = 230;
void ServoL_stop()
    CCAP3H = 0;
/* Control the A4 servo */
void ServoL_back()
    CCAP4H = 243;
    CCAP4H = 230;
void ServoL_stop()
    CCAP4H = 0;
/* Control the A5 servo */
void ServoL_back()
    CCAP5H = 243;
    CCAP5H = 230;
void ServoL_stop()
    CCAP5H = 0;
/* Initialize the PCA and PWM mode */
void Servos_init()
/* Initial Timer0 Generate Overflow PCA */
    TMOD = 0x02;   /* Timer0 Mode2 : 8bit auto reload */
    TH0  = 16;     /* 256-240, 8.125usec Auto-relead (20msec/PWM) */
    TL0  = TH0;
    TCON = 0x10;   /* setb TR0, TCON or 0001,0000*/
    CMOD=0x04;
    CCAPM1=0x42;
    CCAPM2=0x42;
    CCAPM3=0x42;
    CCAPM4=0x42;
    CCAPM5=0x42;
    CCAP1H=0x00;
    CCAP2H=0x00;
    CCAP3H=0x00;
    CCAP4H=0x00;
    CCAP5H=0x00;
    CCON=0x40;
}while(1)
PostPosted: Thu Jun 26, 2008 1:05 pm     Reply with quote
That's 8051 code that you got from here:
http://freewebs.com/80x51/source/servos/pwm_servos.h
Please don't post random code from all over the net.
There is multiple servo code right here in the CCS forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=33183
To find CCS code for multiple servos, you can do a search
with http://www.google.com for this search string. The keywords
are picked to look for servos (plural) and then a CCS-specific
function name that is likely to be used in servo source code:
servos "output_low"
Here are some sample hits:
Here is a project.
http://www.kd7lmo.net/nsrv.html
Here's the code. It's fairly complicated, compared to the link given
above for the forum code. Don't ask me to explain it to you.
http://www.kd7lmo.net/nsvr_servo_source.html
