ascii value of a character
julien lochen
PostPosted: Mon Jun 23, 2008 7:52 am     Reply with quote
Hello, what is the function to get the ascii value of a character, like
int get_ascii(A)
thanks, julien
milkman41
PostPosted: Mon Jun 23, 2008 8:23 am     Reply with quote
I believe you can convert a character to an integer just by adding (int) before the character
ex:
int i;
char c;
i = (int)c;
Wayne_
PostPosted: Mon Jun 23, 2008 8:34 am     Reply with quote
Just use single quotes
int i;
i = 'A';
The compiler will do the rest.
you can also use it to retrieve ASCII codes for other things
'\r'
'\n'
etc.
type conversion should not be required in this case.
PostPosted: Mon Jun 23, 2008 2:57 pm     Reply with quote
In fact there is no conversion.
'A' is a representation, we sometimes place on a byte containing the number 65.
The PIC itself, knows nothing (internally), about 'ASCII'. It receives the byte 65, and if asked to display it on an LCD, it the display generator on this, that turns the number into an 'A'. 'Char', is just an alternative name for an int8.
How it is output by the PIC, depends totally on what format you use in the output routine. So:
Char value;
value=getc(); //Assume 'A' arrives here.
printf("Char %c, decimal %d, hex %2x\n\r",value,value,value);
//Displays on a receiving terminal, Char A, decimal 65, hex 41
value+=32;
//Adds 32 to 65, to give 97. Note dealing with a number
printf("Char %c\n\r",value);
//Displays Char a - now lower case...
