milkman41
Sending X10 commands - help! |
Posted: Thu Jun 19, 2008 10:43 pm |
I would like to preface this by saying Im pretty much a complete n00b when it comes to programming PICs (and in general, really) - having said that, on to my problem! I'm trying to use a PIC to control an X10 TW523, and send commands to a lamp module, but I can't seem to get it right. I've looked at the example code and the driver for X10, and the example code just sends the address code. I've also looked at the documentation for X10 code, and I know what format the code should be in (11 cycles - 2 for start bit, 4/5 for house code, 4/5 for key code/function (can't remember which is 4 and which is 5), then 6 cycles of silence), as per the example code. However, when I try to transmit the functions in this manner, using their binary representations, I can't get it to work. I've tried numerous methods, and this is where I am at right now:
Code: | #include <16F877A.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) //Get house, key codes from rs232 usually, here just using default A1
#include <x10.c>
#include <input.c>
{ printf("ONLINE");
x10_write('A', 1);
//x10_write('A', 1); //the x10_write function already sends the data twice
delay_ms(5000);
I've rewritten the x10_write to also send the function codes, and the delay and print message are just to make sure the program is running properly (trying to turn the lamp off currently). Here is the rewritten x10_write function:
Code: | void x10_write(BYTE house_code, BYTE key_code) {
BYTE i;
i=0;
while (X10_HOUSE_CODES[i]!=house_code)
i++;
house_code=i;
if(key_code<16) {
i=0;
while (X10_KEY_CODES[i]!=key_code)
i++;
key_code=i;
x10_write_bits(7,4,1);
x10_write_bits(house_code,4,0);
x10_write_bits(key_code,5,0);
x10_write_bits(0,6,1);
x10_write_bits(7,4,1); //repeated
x10_write_bits(16,5,1);
This is just the example code provided in EX_X10.c, with just an added little bit add the end to write the command. I can't remember off the top of my head what function 16 is (I think its all off), but I have tried all off, all on, off, on, all lights off, several functions, and they aren't working.
Any help would be greatly, greatly appreciated.
Thank you in advance,
-Nick |
horkesley
horkesley
Posted: Fri Jun 20, 2008 12:23 am |
Another thought, don't you have to sync with mains zero crossing.
Are you doing this somewhere?
Regards _________________ Horkesley Electronics Limited |
Posted: Fri Jun 20, 2008 7:15 am |
yes I have looked at those sites, and from my (albeit limited) knowledge of programming and X10, it appears as if I am doing the right thing, although I clearly am not, seeing as it doesn't work. I took the example code and replicated the signal being sent out, except instead of a key code, I sent out a function code, as specified in the sites. Also, the write_bits function included in the x10 driver waits for the zero crossing. The code seems to transmitting correctly, as the TW523 recieves valid commands (and hte LED winks), but the function code transmission is just not right, I suppose. Thank you though.
Any other suggestions? |
milkman41
Posted: Fri Jun 20, 2008 7:48 am |
that was me^, oops |
