18f4458 adc
morebudwiser
18f4458 adc
PostPosted: Wed Jun 18, 2008 3:04 am     Reply with quote
hi is it possible to measure accurately 1.098 vdc +/- 1mv i have been trying
to read this voltage but when i display it on the lcd the last 2 digits are changing by as much as +/- 30mv. do i need to use an adc with 16bit resolution. i am injecting the dc voltage from a calibrated dc soure straight in to the pic and have decoupled it using 1uf.do i read the adc to quickly cap
#device ADC=12
#use delay(clock = 20000000)
#include <flex_lcd420.c>
float volts;
int16 adc_value;
setup_adc_ports(AN0_TO_AN4|VSS_VREF);         //VREF = 5.00
setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_20);
do{
adc_value = read_adc();
 volts = (float)(adc_value * 5)/4095;
 printf(lcd_putc, "%3.3f\n", volts);
 printf(LCD_PUTC,"adc %Ld",adc_value);
 }while(1);
many thanks Andrew
PostPosted: Wed Jun 18, 2008 4:25 am     Reply with quote
First thing, get rid of 'VSS_VREF'. The supply voltage on the chip, _will_ be varying all the time, by a significant number of mV, as internal processing occurs. You will be 'lucky' to get 1% accuracy using the supply as a Vref.
Add an external 'bandgap' voltage reference, warranted to at least 0.02% accuracy, smooth it well, and ensure the grounding round it and the PIC is good (ground plane). Use a 4.096V ref by choice. The ADC will then read 1mV/step (read up on the design of the PIC ADC, and why the divisor _is_ 4096, not 4095).
Add a small amount of damping anyway, or put the chip to sleep for the actual ADC conversion (otherwise you _will_ pick up noise from the processor).
You then have a good chance of getting a believable 1mV resolution.
morebudwiser
PostPosted: Wed Jun 18, 2008 4:34 am     Reply with quote
thanks
