Dave200 Guest
SPI master to multiple slaves |
Posted: Mon Jun 16, 2008 1:28 pm |
Guys,
I'm trying to get a master to write to x amount of slaves, getting a response. I can get the slaves to respond by toggling pins.
However i cant seem to get the master to respond and am at a lost end.
The SS lines are polled separately and i have tried with just one slave with the same results.
Any help is appreciated.
Thanks in advance
Master Code
void init()
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
//enable_interrupts(INT_RTCC);
//enable_interrupts(INT_SSP);
//enable_interrupts(GLOBAL);
set_tris_a(0x00);
output_a(0x00);
init();
if(!cards_ok)
cards_ok = poll_cards();
switch(card_no)
case 0: output_low(PIN_A3);
case 1: output_high(PIN_A3);
delay_ms(400);
output_low(PIN_A3);
delay_ms(400);
case 2: output_high(PIN_A3);
delay_ms(200);
output_low(PIN_A3);
delay_ms(200);
delay_ms(200);
output_low(PIN_A3);
delay_ms(200);
byte poll_cards()
byte i;
output_low(card1_ss);
for(i=0; i<10; i++)
card_ack = spi_read(0x01);
delay_ms(1);
if(card_ack == 0x10)
card1_success = 1;
card_no++;
output_high(card1_ss);
output_low(card2_ss);
for(i=0; i<10; i++)
card_ack = spi_read(0x02);
delay_ms(1);
if(card_ack == 0x11)
card2_success = 1;
card_no++;
output_high(card2_ss);
return card_no;
Slave Code
#int_SSP
void SSP_isr(void)
spi_data_in = 1;
void init()
setup_spi(SPI_SLAVE|SPI_L_TO_H|SPI_SS_DISABLED);
set_tris_a(0x00);
output_a(0x00);
init();
if(data_ok)
toggle_pins();
if(spi_data_in && (SPI_DATA_IS_IN()))
disable_interrupts(INT_SSP);
if(!SS)
data = spi_read();
delay_ms(1);
if(data == 0x02) // value changed for different slave
spi_write(0x11); // value changed for different slave
delay_ms(1);
data_ok = 1;
spi_data_in = 0;
void toggle_pins(void)
output_low(PIN_A3);
Posted: Mon Jun 16, 2008 1:36 pm |
Quote: | Master Code:
byte poll_cards()
byte i;
Slave Code:
What's wrong in the code above ? |
Posted: Mon Jun 16, 2008 1:43 pm |
I am using a pin on PORTE instead of the SPI SS line, so i thought i would need to disable that option.
I hope that clears that bit up ![Smile](images/smiles/icon_smile.gif) |
Posted: Tue Jun 17, 2008 2:29 am |
With SPI, data goes _both ways at once_. Now, when you perform 'spi_read(0x02)', 2 gets sent, and you receive back the _last_ byte that was in the slave devices buffer. If the slave if setup to respond to the '2', and return an acknowledge byte for this, you have to perform two transfers. So:
SPI_WRITE(2); //_send_ the '2' byte, and ignore the returned byte
delay_us(20); //You _must_ have enough time here for the slave
//to load the response
SPI_WRITE(0); //send a 'dummy' byte, to allow the slave response
//to be read.
RESPONSE=SPI_READ(); //read the byte which the slave sent.
I suspect this is the first problem.
Depending on the clock rates involved, the delay may need to be a lot more. Your slave, has to detect the interrupt, call the handler, return from the handler, go round the loop, and detect the bit has been set, then load the response. Probably in the order of 100+ instructions. At 4MHz, 100+uSec.....
Secondly, what happens in the slave, when the select line goes high?. Does it need _time_ to handle this?. Between your two transmissions, you are raising and lowering the line, for just one instruction cycle. What will the effect of this be?. Depending on the position in the loop, this may be seen or not, and would increase delays.
Finally, 1mSec delay in the slave!. What on earth for?...... This will really slow the response.
