Orcino
INT2 18F2331 |
Posted: Mon Jun 16, 2008 12:32 pm |
In the code below, INT1 work, but INT2 not work,
anybode help-me ?
Orcino
#include <18F2331.h>
#device adc=10
#FUSES BORV27 //Brownout reset at 2.7V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOWINEN //WDT Timer Window Disabled
#FUSES T1LOWPOWER //Timer1 low power operation when in sleep
#FUSES HPOL_HIGH //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
#FUSES LPOL_HIGH //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6
#FUSES PWMPIN //PWM outputs disabled upon Reset
#priority TIMER5,INT_EXT2,INT_EXT1
#ZERO_RAM
int16 RPM1=0,
RPM2=0,
RPM3=0,
RPM4=0,
TEMPERATURA=0,
MEDIA_TEMP=0;
int8 ESTAGIO_1,
ESTAGIO_2,
ESTAGIO_3;
#int_EXT2
void EXT2_isr(void)
++RPM3;
#int_EXT1
void EXT1_isr(void)
++RPM1;
#int_TIMER5
void TIMER5_isr(void)
RPM4=get_timer1();
setup_adc_ports(sAN0|sAN1|VSS_VDD);
setup_adc(ADC_OFF|ADC_TAD_MUL_0|ADC_WHEN_INT0|ADC_INT_EVERY_OTHER);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_power_pwm_pins(PWM_BOTH_ON,PWM_BOTH_ON,PWM_OFF,PWM_OFF);
setup_power_pwm(PWM_CLOCK_DIV_64|PWM_FREE_RUN,1,0,200,0,1,0);
//setup_timer_0(RTCC_EXT_L_TO_H|RTCC_DIV_4);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
setup_timer_5(T5_INTERNAL|T5_DIV_BY_8); // 104 ms
//enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
ext_int_edge( 2, L_TO_H);
ext_int_edge( 1, L_TO_H);
enable_interrupts(INT_TIMER5);
enable_interrupts(GLOBAL); |
Posted: Tue Jun 17, 2008 11:54 pm |
You need to think about why it doesn't work. It could fail if the voltage
level of the input signal was not high enough for a "logic high" level
as specified in the PIC data sheet. This voltage level (Vih) is given
in this section:
Quote: |
25.3 DC Characteristics:
VIH Input High Voltage
with Schmitt Trigger buffer: 0.8 VDD minimum
If your Vdd voltage is +5v, the Vih minimum required level is 5v * .8
= 4.0v for the INT2 pin. You need to check the input signal with a scope.
Another reason for failure would be if the INT2 pin is not programmed
to be an input pin. You can look for this problem in the .LST file of
your program. You should always suspect the Wizard code. Most of
it is not needed, especially when it disables modules in the PIC.
These modules are disabled automatically when the PIC does a power-on
reset.
In the case of the Wizard code, this line causes a lot of problems:
Code: | setup_spi(SPI_SS_DISABLED); |
Here is the .LST file code for that line. Notice that it's doing many
things other than disabling the SSPEN bit. It's doing things to the TRIS
on Port C. This is where the problem is. It's making Pin C5 into an
output pin. That's why INT2 does not work.
Quote: | ..... setup_spi(SPI_SS_DISABLED);
0016: BCF SSPCON.SSPEN
0018: BCF TRISC.7
001A: BSF TRISC.4
001C: BCF TRISC.5 // This makes Pin C5 be an output.
001E: MOVLW 01
0020: MOVWF SSPCON
0022: MOVLW 00
0024: MOVWF SSPSTAT |
The solution is to delete that line of code.
And then, always be suspicious of the Wizard code. You don't normally
need code to disable the SPI module on power-up. It's disabled by
default when the PIC does a power-up. |
Orcino
Posted: Wed Jun 18, 2008 12:43 pm |
Very thanks
the line below was removed and WORKED.
Orcino |
