No activity on I2C Bus with PIC18F4550
jpduell
PostPosted: Sun Jun 15, 2008 4:58 pm     Reply with quote
Hello all! This is my first post and I am admittedly a novice with the PIC series of microcontrollers. I am more familiar with Altera FPGAs and Atmel Microcontrollers... I am trying to broaden my embedded systems knowledge.
As for my question(s)...
I have been trying for quite a while to get some sort of activity from my PIC's I2C interface.
Here are the various I2C init calls I have tried...
#use i2c(Master,Slow,sda=PIN_B0,scl=PIN_B1)
#use i2c(Master,Slow,sda=PIN_B0,scl=PIN_B1, force_hw)
#use i2c(Master,Slow,sda=PIN_C0,scl=PIN_C1)
#use i2c(Master,Slow,sda=PIN_D0,scl=PIN_D1)
and...
i2c_start();
i2c_write(0xAA); //just to wiggle the pins
i2c_stop();
Using an oscilloscope, I see no activity on the pins I bind to the I2C bus. I have pull up resistors on both I2C lines on my breadboard.
I have verified that the chip works by blinking some LEDs.
I am using v4.014 of the CCS C Compiler.
How do I need to set up my pins when I start a project and how would I change them after a project has been made? I believe I made B0 an input/output and B1 just an output.
What am I missing?
Thanks in advance!
-Jason
PostPosted: Sun Jun 15, 2008 6:54 pm     Reply with quote
Do you have pull-up resistors on the SDA and SCL lines ?
You can use 2.2K to 4.7K resistors.
If you have the pull-ups, you will definitly see activity on SDA and SCL
with the following program. I tested it with vs. 4.014.
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
#use i2c(Master, sda=PIN_B0, scl=PIN_B1)
   i2c_write(0x55);
   delay_us(500);
PostPosted: Sun Jun 15, 2008 7:03 pm     Reply with quote
Yes... I was am using two (one for SDA and one for SCL) 10k-ohm resistors pulled up to 3.3V. The PIC is running at 3.3V as well.
PostPosted: Sun Jun 15, 2008 7:21 pm     Reply with quote
Did you try the exact program that I posted ? If you changed it, then
post the modified program. What is your crystal frequency ?
I tested the program on a PicDem2-Plus board running at 5v.
Using the BROWNOUT fuse should not be a problem, because according
to the .LST file, the compiler defaults to BORV20 (2 volts brownout).
You said you're new to PICs. Do you have all the simple things, such
as a pullup on the MCLR pin ?
jpduell
PostPosted: Sun Jun 15, 2008 8:52 pm     Reply with quote
I just tried the program you supplied. I made no changes at first.
I did not have a 4MHz oscillator readily available, so I used a signal generator producing a 4MHz square wave as a clock source.
I still had no activity on SDA or SCL.
I have had the nReset pulled high throughout all my attempts.
I made a few changes and still no luck. I tried using the internal RC oscillator just in case the signal generator route wouldn't work.
#include <18F4550.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#fuses NOWDT, PUT, BROWNOUT, NOLVP //XT,
 setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
   i2c_write(0x55);
   delay_us(500);
As a side note... A couple years back I did design and prototype a 2-channel Air/Fuel ratio gauge making use of the PIC18F4550's onboard A/D converter, a UART output, and lots of I/O for the dual LED bargraphs... and I do not remember having this much trouble. I wonder what I'm doing wrong.
Thanks for you patience!
PostPosted: Sun Jun 15, 2008 11:58 pm     Reply with quote
I think you should check the hardware again. I've done about all I
can do.
