Fill EEPROM memory from usart
hubble
PostPosted: Thu Jun 12, 2008 12:42 pm     Reply with quote
Hi.
How I can fill whole memory from usart?
If I use follow code,
int8 sText[xx], where xx not more 80 (in my example)
int8 value;
int8 i;
while(true){
if(kbhit()){
gets(sText);
lenght=strlen(sText);
for(i=0;i<lenght;i++0
write_eeprom(i,sText[i])
then I can`t fill whole EEPROM memory.
PostPosted: Thu Jun 12, 2008 2:37 pm     Reply with quote
This post has links to code that provide work-arrounds for the array size
limitations of the 16F-series PICs:
http://www.ccsinfo.com/forum/viewtopic.php?t=30456&start=4
With those routines, you can't use gets(), because it expects a
continuous array.
You will need to get the characters individually, in a loop, and write
each one to ram by calling one of the routines shown in the link.
You will need to look for the termination character (carriage return)
to indicate that you should exit from the loop.
When you are done getting the data, you can read the "big array"
by using one of the routines shown in the link, and write the chars
to the eeprom.
hubble
hubble
PostPosted: Tue Jun 17, 2008 11:22 am     Reply with quote
Thank you for answer.
