Measuring time
zipmmcs
Measuring time
PostPosted: Tue Jun 10, 2008 3:56 pm     Reply with quote
I'm new in PIC programming, so please forgive me for the potential silly and obvious failures.
I'd like to measure frequency, especially RPM. I looked into the topics that are about this issue, but I could not implement them to my application, so I started to write my own one.
I'm using an 16F873 with 4MHz Crystal, but later I want to implement the code to an 16F628 (but the latter is not ICD compatible so I needed a more confortable one).
I'd like to measure the frequency on the RA4 pin, and I'm using 2pcs of TIL311 to display (that's why I'm cutting off the least 2 digits and translating the decimal numbers to dcb).
The only thing I know, that the frequency measuring is not working - the others are ok.
How should I modify the code? I think I declared everything fine, but...
Please give me soma advice!
#include <16F873.h>
#device *=16
#FUSES XT, NOPROTECT, BROWNOUT
unsigned char x, pin[4], rpm_digit1, rpm_digit2;
unsigned int rpm_2dig, time, time1, time2, tick;
unsigned long rpm;
float freq;
#define IN_F PIN_A4
#define D1_1 PIN_A0
#define D1_2 PIN_A1
#define D1_3 PIN_A2
#define D1_4 PIN_A3
#define D2_1 PIN_B1
#define D2_2 PIN_B2
#define D2_3 PIN_B4
#define D2_4 PIN_B5
#define STRB PIN_B0
void initialize(){
   freq=0; rpm=0; rpm_digit1=0; rpm_digit2=0; x=0; rpm_2dig=0;
   for (x=1;x<4;x++)
      pin[x]=0;
long count_rpm(){
   while( input(IN_F));
   set_timer1(0);
   time1=get_timer1();
   while(!input(IN_F));
   while(tick < 10){
      if (input(IN_F)>0) tick++;
   disable_interrupts(INT_TIMER1);
   time2=get_timer1();
   time=time2-time1;
   freq=tick/time;            //OK, this is not the correct expression, I have to calculate the right frequency.
   rpm=25*freq;
   return rpm;
void display(long rpm){
//This function indicates the 1000th and 100th digits of the taken value - translates to BCD.
//The correspondence between the freq and the rpm is: 1Hz=25RPM - in case of 4 cyls engine.
//Easy round-up method is to increment the value with 50 then cut off the last 2 digit.
   rpm_2dig=(rpm+50)/100;
   rpm_digit1=(rpm_2dig-rpm_2dig%10)/10;
      output_low(STRB);
   for(x = 0; x < 4; x++){
          pin[x] = bit_test(rpm_digit1,x);
      if (pin[0] > 0) output_high(D1_1);
         else output_low(D1_1);
      if (pin[1] > 0) output_high(D1_2);
         else output_low(D1_2);
      if (pin[2] > 0) output_high(D1_3);
         else output_low(D1_3);
      if (pin[3] > 0) output_high(D1_4);
         else output_low(D1_4);
   rpm_digit2=rpm_2dig-rpm_digit1*10;
          pin[x] = bit_test(rpm_digit2,x);
      if (pin[0]) output_high(D2_1);
         else output_low(D2_1);
      if (pin[1]) output_high(D2_2);
         else output_low(D2_2);
      if (pin[2]) output_high(D2_3);
         else output_low(D2_3);
      if (pin[3]) output_high(D2_4);
         else output_low(D2_4);
   output_high(STRB);
void main(){
   initialize();
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
   enable_interrupts( GLOBAL );
   while(1){
   count_rpm();
   //rpm=2485; //only for testing the display
   display(rpm);
Hope I told every important information belonging to this issue.
Thank you in advance,
Regards,
zipmmcs
PostPosted: Tue Jun 10, 2008 4:52 pm     Reply with quote
You enable the timer1 interrupt, but where is the handler?
And some minor issues:
   for (x=1;x<4;x++)
      pin[x]=0;
Why not start with x=0? Now you are only initializing 3 of the 4 elements.
In count_rpm() you return variable rpm but you never use the returned value, instead you have declared rpm as a global variable and access the value directly. Stick to one method of programming, use global variables or return values but mixing both is confusing and wasting memory. Personally I don't like global variables as they go against the practice of encapsulation and make it impossible for the compiler to optimize RAM memory usage.
RArtz
PostPosted: Wed Jun 11, 2008 10:09 am     Reply with quote
ya, you need to do:
rpm = count_rpm();
display(rpm);
zipmmcs
PostPosted: Mon Jun 16, 2008 12:07 pm     Reply with quote
Thank you for the answers.
Finally me and one of my friend carried out a particular solution using the CCP module. When the code is finished, I will post the whole program.
Regards,
zipmmcs
