'const' and the 'switch' statement
RaulHuertas
PostPosted: Fri Jun 06, 2008 3:26 pm     Reply with quote
Hi
At the beginning of my code I'm setting these variables:
/*COMANDOS*/
const char ENVIARPAQUETEMUESTRAS = 'N';
const char ENVIARUNAMUESTRA = 'E';
const char ENVIOCONTINUODEMUESTRAS = 'C';
const char TERMINARENVIOCONTINUO = 'T';
const char RESPONDEROK = '?';
const char EMPEZARCONEXION = 'S';
const char TERMINARCONEXION = 'X';
const char DESPERTAR = 'D';
const char DORMIR = 'Q';
and then I want to use them in this switch statement:
comando = getc();
    switch( comando ){
        case ENVIARUNAMUESTRA : enviarUnicaMuestra(); break;
        case ENVIOCONTINUODEMUESTRAS : enviarMuestrasContinuamente(); break;
        case ENVIARPAQUETEMUESTRAS : enviarPaqueteMuestras(); break;
        case TERMINARCONEXION : return;
But I'm getting this compilation error:
Error 27, Line..., expression must evaluate to a constant. That is with ENVIOVONTINUODEMUESTRAS .
What's wrong with this code? :S
Also... are enums chars?. If they are chars I'll define again the constants as enums.
PostPosted: Fri Jun 06, 2008 3:42 pm     Reply with quote
See this section in the CCS manual:
#CASE
Syntax: #case
Elements: None
Purpose: Will cause the compiler to be case sensitive.
By default the compiler is case insensitive.
Fix the problem by adding #case to your program.
RaulHuertas
PostPosted: Fri Jun 06, 2008 9:09 pm     Reply with quote
Thanks men, It works. I didn't know that issue. Thanks!
