Rtos message queue question
TheBeefiest
PostPosted: Wed Jun 04, 2008 7:35 pm     Reply with quote
Is there anyway to tell from the list file where the RTOS saves message queue bytes? I would like to see as they are changed in memory, i am only getting the first 2 characters properly, then the last 3 which should be zero, are not zero.
Or is there something wrong with writing multiple bytes, and reading them out sequentially?
This is how I send the bytes
rtos_msg_send(SendDataToAnt, ANT_assign[0]);
         rtos_msg_send(SendDataToAnt, ANT_assign[1]);
         rtos_msg_send(SendDataToAnt, ANT_assign[2]);
         rtos_msg_send(SendDataToAnt, ANT_assign[3]);
         rtos_msg_send(SendDataToAnt, ANT_assign[4]);
         rtos_yield();  //next task
This is how I am receiving them:
if (rtos_msg_poll()) {
      //we have data
      //todo we are not getting the proper bytes from rtos_msg_read()
      rtos_wait(semTX); //wait for transmit buffer availability
      Txbuff.AntSync = MESG_TX_SYNC; //always this sync
      Txbuff.AntDataLen = rtos_msg_read();
      Txbuff.AntMessId = rtos_msg_read();
      TxBuff.AntChecksum = MESG_TX_SYNC ^ Txbuff.AntDataLen ^ Txbuff.AntMessId;
      for (count=0; count < Txbuff.AntDataLen; count++) {
         //all the data
         Txbuff.AntData[count] = rtos_msg_read();
         TxBuff.AntChecksum ^= Txbuff.AntData[count];
      rtos_signal(semTX);  //done using buffer
      rtos_msg_send(AsynchTransmit, MSG_START_TX); //tell transmitter to start send
When calling rtos_msg_read() in the for loop above, i am not getting the same bytes I put in previously.
Compiler version is pcwh 4.073, and the receiving task has a queue=11 (only 5 bytes being sent in this case)
Also testing results show rtos_msg_poll() returns 5, so i am sure the 5 bytes were sent in. I am not sure where they are in ram to confirm exactly what is being sent in, but i know the values of ANT_assign for sure
Matro
PostPosted: Thu Jun 05, 2008 9:01 am     Reply with quote
The first parameter of rtos_msg_send() is the name of the function that receives the message.
Is that the case?
Matro.
