| MPLAB/CCS |
Posted: Fri May 30, 2008 4:07 am |
I am trying to run CCS version 4.071 from within MPLAB 8.00.
When I try to build I get an error saying CCS compiler not installed on this machine.
CCS is installed and works fine.
Any ideas?
Best regards, |
CCS
| MPLAB/CCS |
Posted: Fri May 30, 2008 12:00 pm |
| Thanks for the reply, but I have done what you suggest. |
| MPLAB/CCS |
Posted: Fri May 30, 2008 1:30 pm |
Looking in Help, About I have CCS PCWH version 4.071.
In 'project', 'select language toolsuit' I have C:\Program Files\PICC\Pcw.exe.
Regards |
| Error : " Unknown device type -- Try PCH" |
Posted: Tue Sep 16, 2008 9:17 pm |
I am trying to run CCS version 4.038 from within MPLAB 7.50
When I compile code for pic18F2450, appear error: "Unknown device type -- Try PCH"
Then I replace code for pic18f452, appear error: "Unknown device type -- Try PCH" too.
Can you say to me about this problem!
#include <18F2450.h>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay(clock=20000000)
set_tris_b(0);
output_low(PIN_B1);
output_high(PIN_B1);
ckielstra
Posted: Wed Sep 17, 2008 5:28 pm |
From the error message it looks like you are using the wrong compiler version.
The CCS compiler comes in different flavours for the different PIC families:
PCB for PIC12
PCM for PIC16
PCH for PIC18
PCD for PIC24 and dsPic
These are all command line tools. The Windows versions have similar names but with the character W added. For a complete overview see: http://www.ccsinfo.com/content.php?page=ideoverview
If you do have the correct compiler version then your mistake was you forgot to tell MPLAB which processor you are using: in MPLAB select 'Configure / Select device ... ' and select here your processor type. |
quocloc.pham
| Re: Error : " Unknown device type -- Try PCH" |
Posted: Wed Sep 17, 2008 7:53 pm |
| ckielstra wrote: | From the error message it looks like you are using the wrong compiler version.
PCB for PIC12
PCM for PIC16
PCH for PIC18
I don't think so that! because I use CCS PCH compiler (ccsc v4.038)
and I don't forget tell MPLAB which processor I using.
| Code: | | #include <18F2450.h> |
quocloc.pham
| No error " Unknown device type -- Try PCH" |
Posted: Wed Sep 17, 2008 9:42 pm |
PCB for PIC12
PCM for PIC16
PCH for PIC18
I was configure the same you said, the compiler had already done!
Thanks a lot!! |
