simon630
RTC problem with x1226 |
Posted: Wed Jan 22, 2003 8:07 pm |
dear friends,
i am now having some problems with the rtc module x1226. i wrote the data to the rtc last night. and this morning when i came back, i found that the HR did not trigger. the correct time should be 08:52:00. however, what i read from the RTC was 32:52:00. could anybody help? thx.
following is my routines for rtc:
#define CLKBASE 0x30 //Clock base address
#define _SEC 0x30 //Sec
#define _MIN 0x31 //Min
#define _HR 0x32 //Hour
#define _DAY 0x33 //Date
#define _MTH 0x34 //Month
#define _YR 0x35 //Year
#define _DOW 0x36 //Day of week
#define _Y2K 0x37 //19 or 20
#define _SR 0x3F //Status
char read_rtc(int addr) { //Read 1 byte (see Fig.11 x1226 datasheet)
char data;
i2c_start();
i2c_write(0xDE);
i2c_write(0); //16-bit addr is 00000xxx xxxxxxxx
i2c_write(addr); //For CCR only, 8-bit addr is used
i2c_start();
i2c_write(0xDF);
data=i2c_read(0); //0:No Ack, 1:Ack
i2c_stop();
return(data);
void wr_rtc(int addr, char data) //Write 1 byte to non EE (no delay)
i2c_start();
i2c_write(0xDE);
i2c_write(0);
i2c_write(addr);
i2c_write(data);
i2c_stop();
void write_rtc(int addr, char data)
wr_rtc(_SR,02); //Set WEL (Write Enable Latch)
wr_rtc(_SR,06); //Set both RWEL (Reg WEL) & WEL
wr_rtc(addr,data); //Write byte to rtc
wr_rtc(_SR,0); //Disable write
main(){
write_rtc(_DAY, buf[8]); //Update rtc
write_rtc(_MTH, buf[9]);
write_rtc(_YR, buf[10]);
write_rtc(_HR, buf[11]);
write_rtc(_MIN, buf[12]);
write_rtc(_SEC, 0x01);
write_rtc(_DOW, buf[13]);
write_rtc(_Y2K, 0x20);
while(1){
hr=read_rtc(_HR);
min=read_rtc(_MIN);
Original Post ID: 10915 |
Re: RTC problem with x1226 |
Posted: Thu Jan 23, 2003 3:31 pm |
:=dear friends,
:= i am now having some problems with the rtc module x1226. i wrote the data to the rtc last night. and this morning when i came back, i found that the HR did not trigger. the correct time should be 08:52:00. however, what i read from the RTC was 32:52:00. could anybody help? thx.
Your code looks basically good. You followed the timing
diagram in the data sheet very closely.
I wonder if there is a bug in the chip. What if you really
need a delay after all writes to the chip ? Maybe you should
try that, as a test. Example:
i2c_start();
i2c_write(0xDE);
i2c_write(0);
i2c_write(addr);
i2c_write(data);
i2c_stop();
delay_ms(10); // Add this delay statement
If the change above doesn't completely solve the problem,
then check these other issues:
1. Make sure the "Block Protect" bits are not set.
This would disable writing to the CCR registers.
2. Are you using battery backup ? If not, the data sheet
says you must connect that pin to ground.
3. Did you check if the time is ever incrementing ?
You said you checked it the next day and it was wrong,
but did you check it 5 minutes after start-up, to see
if it was even working at all ?
4. On page 3 of the data sheet, in "Real Time Clock Operation",
it says that when it powers-up after the loss of Vcc and
Vback, the clock will not operate until you write at least
one byte to the clock register. Could this be what's
happening ? There is a bit for "total power failure" that
you can check.
5. The value that you're reading for hours, "32", also
happens to be the hex address of the Hours register.
Is it possible that you've got a mixup in your printf()
statement, and are displaying the wrong variable ?
(Just trying to suggest any possible sources of errors).
6. The data sheet is marked "Preliminary". There could be
bugs. Maybe ask Xicor tech support for a sample driver
and schematic. Even if you have to translate it from
8051 assembly, it would be worth having.
Original Post ID: 10949 |
simon630
Posted: Fri Jan 24, 2003 8:05 pm |
:=:=dear friends,
:=:= i am now having some problems with the rtc module x1226. i wrote the data to the rtc last night. and this morning when i came back, i found that the HR did not trigger. the correct time should be 08:52:00. however, what i read from the RTC was 32:52:00. could anybody help? thx.
:=Your code looks basically good. You followed the timing
:=diagram in the data sheet very closely.
:=I wonder if there is a bug in the chip. What if you really
:=need a delay after all writes to the chip ? Maybe you should
:=try that, as a test. Example:
:=void wr_rtc(int addr, char data)
:=i2c_start();
:=i2c_write(0xDE);
:=i2c_write(0);
:=i2c_write(addr);
:=i2c_write(data);
:=i2c_stop();
:=delay_ms(10); // Add this delay statement
:=If the change above doesn't completely solve the problem,
:=then check these other issues:
:=1. Make sure the "Block Protect" bits are not set.
:= This would disable writing to the CCR registers.
:=2. Are you using battery backup ? If not, the data sheet
:= says you must connect that pin to ground.
:=3. Did you check if the time is ever incrementing ?
:= You said you checked it the next day and it was wrong,
:= but did you check it 5 minutes after start-up, to see
:= if it was even working at all ?
:=4. On page 3 of the data sheet, in "Real Time Clock Operation",
:= it says that when it powers-up after the loss of Vcc and
:= Vback, the clock will not operate until you write at least
:= one byte to the clock register. Could this be what's
:= happening ? There is a bit for "total power failure" that
:= you can check.
:=5. The value that you're reading for hours, "32", also
:= happens to be the hex address of the Hours register.
:= Is it possible that you've got a mixup in your printf()
:= statement, and are displaying the wrong variable ?
:= (Just trying to suggest any possible sources of errors).
:=6. The data sheet is marked "Preliminary". There could be
:= bugs. Maybe ask Xicor tech support for a sample driver
:= and schematic. Even if you have to translate it from
:= 8051 assembly, it would be worth having.
thank you for ur suggestion.
1. :=delay_ms(10); // Add this delay statement
because this development is a time critical application, i dont think i can afford 10ms delay during communication. if really need to put in the dalay, i would rather change another rtc module.
2. i think the battery backup pin may be a cause for this problem. i left it float instead of tying to ground. now doing testing. do not know exactly happens if floating that pin.
3. the rtc incremented after i initialised. only that it could not trigger from 24 to 0. (although "32", also
happens to be the hex address of the Hours register. ??) would u elaborate on this, i didn't quite get it.
Original Post ID: 10985 |
Posted: Fri Jan 24, 2003 11:16 pm |
:=1. :=delay_ms(10); // Add this delay statement
:=because this development is a time critical application, i dont think i can afford 10ms delay during communication. if really need to put in the dalay, i would rather change another rtc module.
:=2. i think the battery backup pin may be a cause for this problem. i left it float instead of tying to ground. now doing testing. do not know exactly happens if floating that pin.
:=3. the rtc incremented after i initialised. only that it could not trigger from 24 to 0. (although "32", also
:=happens to be the hex address of the Hours register. ??) would u elaborate on this, i didn't quite get it.
Hopefully it will be the battery backup pin.
With respect to the "32", I just meant that, possibly, in
your diagnostic printf statements, that number might have
gotten juxtaposed accidently and misinterpreted as the Hours.
That comment was just a shot in the dark.
Original Post ID: 10987 |
simon630
Posted: Mon Jan 27, 2003 6:02 am |
:=:=1. :=delay_ms(10); // Add this delay statement
:=:=because this development is a time critical application, i dont think i can afford 10ms delay during communication. if really need to put in the dalay, i would rather change another rtc module.
:=:=2. i think the battery backup pin may be a cause for this problem. i left it float instead of tying to ground. now doing testing. do not know exactly happens if floating that pin.
:=:=3. the rtc incremented after i initialised. only that it could not trigger from 24 to 0. (although "32", also
:=:=happens to be the hex address of the Hours register. ??) would u elaborate on this, i didn't quite get it.
:=Hopefully it will be the battery backup pin.
:=With respect to the "32", I just meant that, possibly, in
:=your diagnostic printf statements, that number might have
:=gotten juxtaposed accidently and misinterpreted as the Hours.
:=That comment was just a shot in the dark.
still can not work even i connect battery backup pin to either ground or a backup source. why?
Original Post ID: 11025 |
Posted: Mon Jan 27, 2003 1:18 pm |
:=still can not work even i connect battery backup pin to either ground or a backup source. why?
I don't know.
I think you should email the tech support department at Xicor.
Ask them for some sample driver code. I think it's very
likely, that the Engineering department at Xicor has developed
some sample code. It might not be in C. It might be in
in 8051 assembly language. But it doesn't matter. Get that
sample code and study it carefully. Then translate it to C.
Also, ask them for a schematic of a demonstration board for
this chip. Or, any schematic that they have.
Your goal in doing this, is to find out about any small details
that will make the chip work.
Original Post ID: 11044 |
MJ Guest
Posted: Wed Jan 29, 2003 10:23 am |
Have you noticed that RTC registers use BCD coding?
Regards,
MJ
Original Post ID: 11097 |
