KBD.C and the keyboard pinout
Hans Zimmer
PostPosted: Wed Jan 22, 2003 8:31 pm     Reply with quote
Does anyone have the schematic diagram of the board used by the file KBD.C (CCS Software Prototyping Board) or, at least, the pinout used by the keyboard, which pins are used by each row and column and if is there any pin with an external pull-up resistor.
___________________________
Original Post ID: 10917
Re: KBD.C and the keyboard pinout
PostPosted: Thu Jan 23, 2003 12:49 pm     Reply with quote
:=Does anyone have the schematic diagram of the board used by the file KBD.C (CCS Software Prototyping Board) or, at least, the pinout used by the keyboard, which pins are used by each row and column and if is there any pin with an external pull-up resistor.
I don't have a schematic. This post may help:
<a href="http://www.pic-c.com/forum/general/posts/10367.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/10367.html</a>
Original Post ID: 10944
