Loading 13 bits to PORTD
Bryan
PostPosted: Thu Jul 31, 2003 10:48 am     Reply with quote
Hi!
If i load long integer variable to PORTD, which part of byte (upper or lower) will be loaded to PORTD? Thanks in advance.
bryan
Original Post ID: 144516523
Mark
Re: Loading 13 bits to PORTD
PostPosted: Thu Jul 31, 2003 10:56 am     Reply with quote
Lower byte unless you do something like (int8)(x>>8) where x is a long (16bit).
:=Hi!
:= If i load long integer variable to PORTD, which part of byte (upper or lower) will be loaded to PORTD? Thanks in advance.
:=bryan
Original Post ID: 144516524
Douglas Kennedy
PostPosted: Thu Jul 31, 2003 11:01 am     Reply with quote
:=Hi!
:=bryan
A way to find an answer and gain insight is to look at the .lst file which is generated. You'll see which part is moved to portD
when you in c code assign a 16 bit value to an 8 bit port.
Original Post ID: 144516525
