Basic problem understanding EEPROM specs !!!
arunb
PostPosted: Mon Jul 28, 2003 7:37 am     Reply with quote
Hi All,
I have been going through EEPROM specs, the memory specs is given as
128K x 8 , does this mean that memeory is something like this
F F F F ........( 128x1024 times).
Also in some memory chips only the maximum capacity is given, like 24LC04B.
Kindly advise..
arun
Original Post ID: 144516430
Pete Smith
Re: Basic problem understanding EEPROM specs !!!
PostPosted: Mon Jul 28, 2003 8:08 am     Reply with quote
:=Hi All,
:=I have been going through EEPROM specs, the memory specs is given as
:=128K x 8 , does this mean that memeory is something like this
:=F F F F ........( 128x1024 times).
128k by 8 is 128kilo bytes. The chip itself will be advertised as a 1Mbit (128k entries by 8 bits wide, but it could just as easily be 64k by 16 bits wide :-)
I think you meant FF 128*1024 times. FFFF is 2 bytes.
:=Also in some memory chips only the maximum capacity is given, like 24LC04B.
If nothing else is given, other than the size, I always assume that the size is in KBits.
24LC04 will be a 3v part, 4 kbits = 512 bytes * 8 bit.
HTH
Pete.
Original Post ID: 144516433
