RS-232 by 16F873
FRANCESC
RS-232 by 16F873
PostPosted: Sun Jul 06, 2003 2:08 pm     Reply with quote
Hi all
I need comunicate 2 PICS 16F873 by RS-232.
I write two independent programs.
Send Program:
include <16f873.h>
#use delay(clock=4000000,RESTART_WDT)
#use RS232(BAUD=9600,BITS=8,PARITY=N,XMIT=PIN_C6,RCV=PIN_C7,RESTART_WDT)
#use I2C(MASTER,SDA=PIN_B6,SCL=PIN_B7,SLOW,RESTART_WDT)
#use fast_io(A)
#use fast_io(B)
#define AnalogWrite 0x90
#define AnalogRead 0x91
#define Reg_Control_Inc 0x04
LONG INT K1,K2,K3,K0;
void read_8591(void)
i2c_start();
i2c_write(AnalogWrite);
i2c_write(Reg_Control_Inc);
Main()
read_8591();
i2c_start();
i2c_write(AnalogRead);
K0=i2c_read();
K1=i2c_read();
K2=i2c_read();
K3=i2c_read(0);
i2c_stop();
puts(K0);
delay_ms(200);
puts(K1);
delay_ms(200);
puts(K2);
delay_ms(200);
puts(K3);
delay_ms(200);
Receive program
#include <16f873.h>
#use fast_io(A)
#use fast_io(B)
#include <lcd2.c>
LONG INT K,K1,K2,K3,K0;
main()
K=K0;
lcd_gotoxy(1,1);
lcd_putc(K\%10);
K=K1;
lcd_gotoxy(5,1);
lcd_putc(K\%10);
K=K2;
lcd_gotoxy(1,2);
lcd_putc(K\%10);
K=K3;
lcd_gotoxy(5,2);
lcd_putc(K\%10);
The program not run and display not read nothing.
Please Help me ???
Many thanks
Original Post ID: 144515751
Kenny
Re: RS-232 by 16F873
PostPosted: Sun Jul 06, 2003 4:44 pm     Reply with quote
<font face="Courier New" size=-1>:=Hi all
:=I need comunicate 2 PICS 16F873 by RS-232.
:=I write two independent programs.
:=Send Program:
:=include <16f873.h>
:=#use delay(clock=4000000,RESTART_WDT)
:=#use RS232(BAUD=9600,BITS=8,PARITY=N,XMIT=PIN_C6,RCV=PIN_C7,RESTART_WDT)
:=#use I2C(MASTER,SDA=PIN_B6,SCL=PIN_B7,SLOW,RESTART_WDT)
:=#use fast_io(A)
:=#use fast_io(B)
:=#define AnalogWrite 0x90
:=#define AnalogRead 0x91
:=#define Reg_Control_Inc 0x04
:=LONG INT K1,K2,K3,K0;
:=void read_8591(void)
:= i2c_start();
:= i2c_write(AnalogWrite);
:= i2c_write(Reg_Control_Inc);
:=Main()
:= while(1)
:= read_8591();
:= i2c_start();
:= i2c_write(AnalogRead);
:= K0=i2c_read();
:= K1=i2c_read();
:= K2=i2c_read();
:= K3=i2c_read(0);
:= i2c_stop();
:= puts(K0);
:= delay_ms(200);
:= puts(K1);
:= delay_ms(200);
:= puts(K2);
:= delay_ms(200);
:= puts(K3);
:= delay_ms(200);
:=Receive program
:=#include <16f873.h>
:=#use fast_io(A)
:=#use fast_io(B)
:=#include <lcd2.c>
:=LONG INT K,K1,K2,K3,K0;
:=main()
:= lcd_init();
:=K=K0;
:=lcd_gotoxy(1,1);
:=lcd_putc(K\%10);
:=K=K1;
:=lcd_gotoxy(5,1);
:=lcd_putc(K\%10);
:=K=K2;
:=lcd_gotoxy(1,2);
:=lcd_putc(K\%10);
:=K=K3;
:=lcd_gotoxy(5,2);
:=lcd_putc(K\%10);
:=The program not run and display not read nothing.
:=Please Help me ???
:=Many thanks
There are a few problems that I can see.
Disable watchdog until last stage of code development, it can cause lots of problems during debugging.
You need a line like the following on both PICs:
#fuses HS,NOWDT,NOLVP,PUT
Need to #include lcd.c on the receiver.
With #use fast_io you need to set the tris manually.
There's nowhere in the receiver code where the incoming data bytes are handled. See recent posts about receiving a byte and putting it into a circular buffer in the interrupt service routine.
Also break the problem into manageable pieces, eg comment out the i2c and lcd code, instead use leds on a port of the receiver (or a second rs232 port for printf debugging) to prove the link.
Regards
Kenny </font>
Original Post ID: 144515753
SebDey
PostPosted: Mon Jul 07, 2003 12:57 am     Reply with quote
:=<font face="Courier New" size=-1>:=Hi all
:=:=I need comunicate 2 PICS 16F873 by RS-232.
:=:=I write two independent programs.
:=:=Send Program:
:=:=include <16f873.h>
:=:=#use delay(clock=4000000,RESTART_WDT)
:=:=#use RS232(BAUD=9600,BITS=8,PARITY=N,XMIT=PIN_C6,RCV=PIN_C7,RESTART_WDT)
:=:=#use I2C(MASTER,SDA=PIN_B6,SCL=PIN_B7,SLOW,RESTART_WDT)
:=:=#use fast_io(A)
:=:=#use fast_io(B)
:=:=#define AnalogWrite 0x90
:=:=#define AnalogRead 0x91
:=:=#define Reg_Control_Inc 0x04
:=:=LONG INT K1,K2,K3,K0;
:=:=void read_8591(void)
:=:= i2c_start();
:=:= i2c_write(AnalogWrite);
:=:= i2c_write(Reg_Control_Inc);
:=:=Main()
:=:= while(1)
:=:= read_8591();
:=:= i2c_start();
:=:= i2c_write(AnalogRead);
:=:= K0=i2c_read();
:=:= K1=i2c_read();
:=:= K2=i2c_read();
:=:= K3=i2c_read(0);
:=:= i2c_stop();
:=:= puts(K0);
:=:= delay_ms(200);
:=:= puts(K1);
:=:= delay_ms(200);
:=:= puts(K2);
:=:= delay_ms(200);
:=:= puts(K3);
:=:= delay_ms(200);
:=:=Receive program
:=:=#include <16f873.h>
:=:=#use fast_io(A)
:=:=#use fast_io(B)
:=:=#include <lcd2.c>
:=:=LONG INT K,K1,K2,K3,K0;
:=:=main()
:=:= lcd_init();
:=:=K=K0;
:=:=lcd_gotoxy(1,1);
:=:=lcd_putc(K\%10);
:=:=K=K1;
:=:=lcd_gotoxy(5,1);
:=:=K=K2;
:=:=lcd_gotoxy(1,2);
:=:=K=K3;
:=:=lcd_gotoxy(5,2);
:=:=The program not run and display not read nothing.
:=:=Please Help me ???
:=:=Many thanks
:=There are a few problems that I can see.
:=Disable watchdog until last stage of code development, it can cause lots of problems during debugging.
:=You need a line like the following on both PICs:
:=#fuses HS,NOWDT,NOLVP,PUT
:=Need to #include lcd.c on the receiver.
:=With #use fast_io you need to set the tris manually.
:=There's nowhere in the receiver code where the incoming data bytes are handled. See recent posts about receiving a byte and putting it into a circular buffer in the interrupt service routine.
:=Also break the problem into manageable pieces, eg comment out the i2c and lcd code, instead use leds on a port of the receiver (or a second rs232 port for printf debugging) to prove the link.
:=Regards
:=Kenny </font>
perhaps a silly answer, but where are the getc() in your receive program ???
I think that by writing K=K0...K=K1...K=K2 etc you intend to do K=getc(), where the value returned by getc() will be the last character (K0, K1, or Kx) you sent from the other pic.
Hope I didn't misunderstood your code or question...
Original Post ID: 144515757
