Old PIC16F506 Reason for reset from STATUS register
Eddy71ua
PostPosted: Tue Jan 13, 2026 4:25 am     Reply with quote
I am reading the datasheet for this controller, and it describes how to read the STATUS register assembler commands.
State of the TO and PD bits to understand what woke the controller from sleep mode.
What simple C commands can be used to do this?
PostPosted: Tue Jan 13, 2026 6:24 am     Reply with quote
Googling for: "ccs picc get reset reason" you get the following:
Determine the reset cause using the built-in function restart_cause().
Usage: Call restart_cause() as early as possible in your main() function, as subsequent operations can change the returned status bits.
Returned Values: The function returns a value indicating the reason for the restart. Check the CCS C user manual for the specific defines for your PIC model, but common reasons include:
WDT_FROM_SLEEP or WDT_TIMEOUT: Watchdog timer expired.
MCLR_FROM_RUN or NORMAL_POWER_UP: External Master Clear (MCLR) pin reset or a normal power-on event.
BROWNOUT_RESE: A brownout (power supply voltage dip) occurred.
STACK_UNDERFLOW or STACK_OVERFLOW: A software issue related to the program stack.
CODE_GUARD_RESE: A security violation reset
Example Code:
#include <16F877A.h> // Include appropriate header for your PIC
#fuses NOWDT, HS, NOBROWNOUT, NOLVP // Example fuses
void main() {
int reason = restart_cause();
// Use the value of 'reason' to log or handle the specific reset event
if (reason == WDT_TIMEOUT) {
// Handle WDT reset
// ... other checks
Eddy71ua
PostPosted: Tue Jan 13, 2026 7:11 am     Reply with quote
Thank you.
But I have another question: when the controller wakes up from pressing the button, how should the flags be set in the STATUS register?
PostPosted: Wed Jan 14, 2026 1:57 am     Reply with quote
What button?????.
Depends what this does.
If this is not a 'restart', but a wake using an interrupt for example,
the status won't be affected.
Eddy71ua
PostPosted: Wed Jan 14, 2026 2:18 am     Reply with quote
I put the controller to sleep and allow it to wake up when the status of port B lines changes.
I have already read in the datasheet that when the controller wakes up due to a change in the status of the lines, the RBWUF bit will be set to 1 in the STATUS register.
It remains to be understood how to check this without assembler inserts in the code...
Rolling Eyes
PostPosted: Wed Jan 14, 2026 5:22 am     Reply with quote
What I would do is print out the variable reason after the wake-up to
see what the code is. Then, if not already defined in the header file, define it
myself as a constant just like the other reason codes.
PostPosted: Wed Jan 14, 2026 5:36 am     Reply with quote
OK.
If you have an RBWUF bit, you have to be talking a really old baseline
chip like the 12F508. Why?. The more modern chips are a lot easier to
use and usually cheaper.
If so you will have to enable wake from sleep with the setup_wdt
call, and have suitable pullups on the pin.
Just setup a #byte to register 3, then test bit 7 of this.
You will run out of space really quickly if you are on a chip like the 508.
#byte STATUS=getenv("SFR:STATUS")
   if (bit_test(STATUS,7))
      //Here code for wake up on B change
   //Other code
On most chips, you could use:
#bit RBWUF=getenv("BIT:RBWUF")
and just test this. However on your chip this isn't supported.
You can use:
#bit RBWUF=STATUS.7
//Then
    if (RBWUF)
Eddy71ua
PostPosted: Thu Jan 15, 2026 2:08 am     Reply with quote
In the forum thread title, I mentioned that I am using an old PIC16F506. I have a ready-made device, which is very simple. However, a friend asked me to add a power button to turn the device on and off. That is what I am trying to do now, without replacing the microcontroller.
Confused
PostPosted: Thu Jan 15, 2026 6:18 am     Reply with quote
It is a foul little chip, and is now so easy to replace with once that works
much better, that is it honestly worth wasting the time to do this?.
The basic design is over 25 years old!.... The original versions were 'C'
(so OTP), but the 'F' versions only changed the memory used, and kept
all the problems. These appeared about 15 years ago.
Problem is that the memory space is so small that you may well find
yourself running out of ROM. Your approach will have to be to read restart_cause, and the top bt as I show, then in the main code you will
have to add the setups to configure the CONFIG register to support the
wake up from pin change (this is done by setup_wdt).
You will also have to change all the configuration of the registers so
they are left uninitialised at boot, and add this into the main code so
it doesn't happen on the reboot. I can see just adding this adding perhaps
a total of about 50 instructions to the code, hence the worry about the
ROM size.....
PostPosted: Thu Jan 15, 2026 8:34 pm     Reply with quote
great Mr. T make me feel old ! Pretty sure I have 1/2 tube of 508s in the same drawer as the 16C71s and 16C84s. Pretty chips, quartz windows on top, 15 minutes to erase, LOTS of 'coffee breaks'..... good old dayze !!!
agree there has to be a drop in replacement, heck do they still sell 508s ??
PostPosted: Fri Jan 16, 2026 2:47 am     Reply with quote
The funny thing was these were horrid chips, for doing the wake up on
pin change, even when they launched. Some of the other chips launched at
similar times were much better.
As covered, he is going to have to add much more than he probably thinks,
So, change all the variable declarations so they don't initialise the values.
Change the code boot, so it detects if it is a restart from sleep, and if
not, initialise the variables.
Add to the main code the setup to enable this wakeup. Since this uses the
same register as the watchdog, care here to ensure he doesn't get something
unexpected here.
Touch wood, if the existing code is reasonably well written, he can do this reasonably easily. However if so the code would be so easy to move to
a chip that has more capabilities and will often be cheaper, like the PIC16F15323......
Eddy71ua
PostPosted: Fri Jan 16, 2026 10:00 am     Reply with quote
You're probably right, I could have just bought a new chip and saved myself the headache.
I guess I was feeling nostalgic for the old chips and the struggles I had with the first PIC16C54s and similar ones Smile
Everything worked out and is already up and running. I enjoyed helping my friend.
Rolling Eyes
